Old 08-15-2018, 05:49 PM   #1
Tires... 285 / 265's???
So I am going to order up some GoodYear DuraTrac's, supposed to be an excellent winter tire. Mostly road running, some off pavement but mostly going for looks.
Truck is '11 E-150. Has a 2.25" Body Lift to accommodate wheelchair lift and floor drop. Been reading most guy's run up to a 265/75/16 with no lift at all so wondering if I can squeeze a 285/75/16 in there with my "lift"?
Also considering, but not immediately doing the MOOG CC880's up front and rear spings rebuilt to get another 1-1.5" height.
What you guy's thinkin I should choose, 265/285's?
GimpyGolden is offline   Reply With Quote
Old 08-15-2018, 06:14 PM   #2
I don't know if the 285s will fit. I have a 4" lift from weldtec and 265's are pretty close to perfect. 285's wouldnt fit on mine. They may fit in the wheel well, but they will likely rub at full lock.
Old 08-15-2018, 07:50 PM   #3
Bbasso's Avatar
I'd stick with 265. Tried snd works...
Rob.
Current:
And had three other E350s...
Old 08-15-2018, 08:17 PM   #4
I agree. 265s and Duratracs are great tires.
Old 08-15-2018, 09:01 PM   #5
Well then, that's decided.
Anyone have any pic's with 2-4" lift and the 265's?
Old 08-15-2018, 09:48 PM   #6
This ended up being about a 6” lift with 265s
Old 08-15-2018, 10:04 PM   #7
ID:	22314Click image for larger version
This is the 4” weldtec kit with 265s
Old 08-15-2018, 10:05 PM   #8
That does look about perfect.
I guess I'd expect mine to look pretty close after 1.5" Coils/Leafs.
Old 08-15-2018, 10:06 PM   #9
I could have done 285s with the 6” kit but that thing is huge and top heavy as it is. Plus, I didn’t want to want to re-gear it.
Old 08-16-2018, 10:19 AM   #10
BenJJ's Avatar
I run 285s on a 2.5" lift. The only time I get a little bit of rubbing is when I air down off road and go to full lock. Other than that, especially just driving on the highway, I haven't had any issues. When I had the lift and tires put on (Agile Off road) I think they did some mod to my stock front bumper to make the tires clear which was basically just notching out the bottom corners.
Couldn't one good picture of the fit, but attached a couple that hopefully gives you an idea of what it looks like.
BenJJ is offline   Reply With Quote
Vantastic
maxx
Faultine
rizzabove
