your other wheels should have offset stamped in the back side of the hub in between the lug holes. if for some reason they aren't, lay a flat edge across the back of the wheel and measure to the mounting surface of the wheel. that will tell you your backspacing.
I see 16.5 wheels for sale rather often on craigslist.
