05-18-2015, 05:07 AM
#21
Re: Wheel spacer question
Originally Posted by BajaSportsmobile
I think water intrusion is the biggest culprit.
How does water enter and how can it be prevented or greatly reduced?
05-18-2015, 08:13 AM
#22
Make sure your vent tube is properly routed and has the little cap thing on it.
Water can get in through condensation as air is drawn in through the vent.
Don't stop in deep water crossings.
Drive long enough to get the rear axle up to temp on a regular basis to evaporate out the moisture.
Fluid changes based on usage...
AgileOffRoad.com
05-18-2015, 08:41 AM
#23
Let's talk fluid changes......(sorry for the hijack)
What's the recommended fluid? Whatever the manual calls out? Same stuff for semi-float and FF? Are the fluid requirements different for limited slip?
Just remove the pumpkin cover, drain and refill up to the fill hole?
When the cover is off, is there an easy way to verify LSD?
05-18-2015, 09:56 AM
#24
Ok this is all new to me so please keep it in mind, if I understand correctly, you guys are saying that the OEM rear axle is not meant to have all the weight we are adding on them never mind the spacers (I'm not doing the 4x4 conversion simply the cargo area)
DIY conversion build, extended 2010 Ford 5.4L E250 + high top, from Montreal Canada, new to all this so please be patient and clear with me (never built or camped in a van yet)
05-18-2015, 10:10 AM
#25
Depends on your axle.. Full Floater or Semi Floater, the vans came with both. And some would argue the semi is inadequate.
06-17-2015, 07:50 PM
#26
I know I'm new and haven't introduced myself yet, but give a look at Adaptec for adapters and spacers. Custom sized, hubcenteric and lugcentric available. They are big in the watercooled VW world.
http://www.motorsport-tech.com/special/ ... p_car.html
I'm Mike btw
06-17-2015, 10:13 PM
#27
Welcome Mike!
10-02-2015, 12:28 PM
#28
Cleaned my van yesterday and noticed one of the lug studs was snapped off one of the rear tires. The rear wheels have spacers that I need to get off to replace the studs. The nuts came off with a breaker bar, a pipe, and a lot of elbow grease but the spacer still won't budge. Anyone have any tricks for getting it off?
Thanks!
10-02-2015, 02:20 PM
#29
Heat, PB blaster, and a bigger hammer
10-02-2015, 05:56 PM
#30
Originally Posted by carringb
and a bigger hammer
*datsmyboy*
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
