Old 09-19-2015, 01:01 PM   #1
Aluminess Front Receiver
Trying to find someone who has installed the Aluminess front receiver in their Aluminess winch bumper .
thanks!
carl
2010 SMB
Old 09-19-2015, 04:17 PM   #2
BajaSportsmobile's Avatar
Re: Aluminess Front Receiver
Bolts right on with four bolts supplied and all holes are already there.
What are you looking for?
AgileOffRoad.com
Old 09-20-2015, 06:03 AM   #3
The Aluminess bumper requires that you "cut out" a section of bumper to install the receiver. What you cut out can make the install look good or bad depending on how much aluminum you remove. I just finished my install and if anyone is doing one, let me know I can send a picture of what I cut out.
carl
2010 SMB
Old 05-28-2016, 12:00 AM   #4
If it's not too much trouble to post up that photo of the front receiver hitch install I'm about to do one myself and would like to see what it entails.
Famous Mockingbird is offline   Reply With Quote
Old 05-29-2016, 07:12 AM   #5
hitch picture
Little cutting but easy job.
carl
2010 SMB
Old 05-31-2016, 11:30 PM   #6
rltilley's Avatar
I had Aluminess install one when I was last out there. A couple of poor pictures are below:
http://www.sportsmobileforum.com/for...ture26331.html
http://www.sportsmobileforum.com/for...ture26330.html
rltilley is offline   Reply With Quote
Old 06-01-2016, 09:03 AM   #7
rallypanam's Avatar
Just a reminder, these are for low weight only.. Not designed to hold much more than a bicycle..
Old 06-01-2016, 03:37 PM   #8
ridintall's Avatar
Hmm, how much weight are we talking about? I have a fishing basket that I use in the summer filled with 10 gallons of water and firewood. It's gotta be 200 lbs loaded.
Sent from my SM-T810 using Tapatalk
ridintall is offline   Reply With Quote
Old 06-01-2016, 04:11 PM   #9
rallypanam's Avatar
Aluminess can tell you for sure, I just remember it was lower than I could carry a small motorcycle with...
Old 08-23-2016, 07:43 AM   #10
stageracer's Avatar
<<Hmm, how much weight are we talking about? I have a fishing basket that I use in the summer filled with 10 gallons of water and firewood. It's gotta be 200 lbs loaded.>>
Aluminess said 150 lbs. when I put mine on. I used a Dremel and file to cut the bumper to fit. I'm only using it for a bike rack and one of those combo lock key storages that fit in the receiver
stageracer is offline   Reply With Quote
Loud Mobile
pinz712
Behemoth
Besags
