11-03-2010, 06:06 PM
Not Able to Tow
Hello all, kinda new here.
I bought my 2010 4x4 Quadvan new for travel and towing.
All factory towing accessories and airbags are on my van.
Thing is with a rear mounted tire on the Aluminess tire mount(on the stock bumper), I have no clearance to pull a trailer. Turning left is out of the question.
A hitch extension is not rated for 520 lbs tongue weight or a 4500 lb trailer (Tango).
About 350 lb tongue weight and 3500 lb trailer weight max for the hitch extensions.
I can get rid of the tire mount (pull the floor storage box, weld the floor back and tire back underneath) or get rid of the trailer, or....
Any options????
Right now I am foiled at pulling a trailer with my Quadvan and exterior tire mount...
Not happy.
Two wheels or four, its all good. :-)
'10 E-350 EB V-10 QuadVan 4x4, SMB penthouse top, Van Specialties interior
11-03-2010, 06:41 PM
Re: Not Able to Tow
11-03-2010, 07:05 PM
Re: Not Able to Tow
I'm having a similar problem with my flatbed trailer. I've also got the Galley Box which makes it worse. I've decided to move the trailer jack back and make it cleaner to turn.
Paul
2007 RB50 6.0 PSD Walker Evans Streetlocks, 305X70X17 Terra Grapplers Custom Aluminess Roof Rack, ETC ETC
11-03-2010, 09:09 PM
Re: Not Able to Tow
There are two hitches for a ford van one is the factory flat bumper and then there is one for a factory Step Bumper. The step bumper hitch extends out further but keeps your tow rating? Good luck
Putnam Hitch; 98-01 FORD VAN - FULL SIZE (EXCEPT 98 CLUB VAN)(EXCEPT 97-99 W/STEP BUMPER)(EXCEPT DUAL EXHAUST) 107
25220
Putnam Hitch; 04-06 FORD VAN - FULL SIZE
(138" WHEEL BASE) 131
25136
Putnam Hitch; 99-02 FORD VAN - FULL SIZE
(WITH STEP BUMPER ONLY) 139
25048
Putnam Hitch; 98-04 FORD VAN - FULL SIZEWITH OR W/O STEP BUMPER 117
11-03-2010, 09:25 PM
Re: Not Able to Tow
I like the tanks/batteries swap idea. Never thought of that. ...Hate to mod a new trailer.
That ought to kill the warranty.
The trailer tongue seems abnormally short to me, but this is my first travel trailer, so I'm not sure about that.
Clearances are tight.
So far any hitch extension has not been spec'd to handle my 520 lb TW/4500 lb trailer weight.
Oh, even with the tanks/batts swap room is minimal.
11-03-2010, 10:36 PM
Re: Not Able to Tow
Have you looked into a longer hitch, not a hitch extension?
11-03-2010, 10:42 PM
Re: Not Able to Tow
Skip the hitch extensions.
Most adjustable hitches stick out further than a fixed ballmount.
I have pretty much the same setup on my van, and turning with trailers using the adjustable hitch or a WD hitch is not a problem. If I use a fixed ballmount, then I use a Valley 8" extension.
Your receiver is inset more than others. Like mentioned above, you could switch to the Step bumper model, and it'll stick out more.
I have a Reunel bumper-receiver on mine:
11-04-2010, 01:09 AM
Re: Not Able to Tow
I'm a little confused here.
Factory step bumper. Factory receiver.
Wrong factory receiver?
Would/does Ford have a different receiver for each style of bumper?
Different receivers would/could sit farther back gaining clearance?
I will be at the Ford dealer tomorrow.
I will look into the possibility of two receivers available.
Then to aftermarket and check for how far to the rear they sit.
A weight distribution hitch gains me only 6" in length apparently.
I don't believe I have an interference problem on a new van and trailer.
It shouldn't be.
FWIW, I did pull the trailer home when the van was stock and 2wd.
I thought it was close then but I thought thats just the way it is.
11-04-2010, 01:21 AM
Re: Not Able to Tow
I just loaded this pic below off of the random galleries.
Huge difference in van to trailer distance compared to mine...
11-04-2010, 02:05 AM
Not Able to Tow
Put your spare in/on the trailer when you tow.
2005 Ford E-350 Diesel Sportsmobile
EB 102 Voyager top, 3.55 rear, Mobil 1 all around
270 amp alternator, billet water pump, coolant filter kit,
aluminum radiator, X-Monitor with pyro, trans temp, boost
+ Scan Gauge & SCT Live Wire (Economy)
