Re: Trailer
From Schutt Feb, 2014:
For a limited time we are including the Elevating Cargo Rack System at no additional charge. This is a $1595 value.
The base model XVENTURE XV-1 trailer is $11,995 which includes the following:
XVENTURE Trailer – All Aluminum Construction, Includes the following plus standard trailer amenities such as front wheeled jack and rear adjustable vertical stabilizers, etc..
Fully D.O.T. compliant in all 50 states.
3 Piece Step-Style Fenders
Fender Receivers – For Accessory Attachments
Large Front Storage Cabinet – 62 wide x 22 tall x 19 front to back. All Aluminum.
Multi-Axis Max Hitch
Electric Drum Brakes
Dual independent manual brake controls
Emergency Break-Away brake actuator
Through-Drawbar IVC Cable with right angle cover plate incorporating a metal mesh Cable Stretch Eliminator Sleeve and Metal IVC Plug
Reverse Lights / Area Lights – Super bright white 24 device LED modules – These turn on when the tow vehicle is placed in reverse, and are also able to be switched on from the power distribution control center to act as large area illumination lighting.
Power Distribution Center - Completely wired with 6 fused switchable supply ports - This allows you to integrate up to 6 electronic accessories like additional lights, compressors, pumps, charging units etc., to a fused circuit that is remotely switchable from the control center switch block.
Wiring harness runs through chassis tubes for optimal protection
Exterior mounted weather proof 110V Shoreline-In receptacle
Exterior mounted weather proof 110V output receptacle
Exterior mounted USB and solar panel Input/Output ports
50 AH Power Generator with integrated 110V inverter, and charger. - We have optional GoalZero Yeti power systems available including Solar Panels.
Cargo bed mounted 12VOLT receptacles - Receptacles on either side of bed at rear
Lighted license plate mount on tailgate
Truxedo Toneau Cargo Bed Cover
Poly Urea (Line-X) Coating - Cargo Bed Interior and Front Exterior Wall, Chassis, Fenders, Storage Cabinet
3M Body Wrap in the color of your choice - Exterior Side Panels (Sides and Tailgate) Some Graphic Design implementation included.
2: Tires and Rims (Includes Spare) 16 x 6 6-5.5
2: Steel Rims with LRR (Low Rolling Resistance) LT 7.50-16E Tire
Rear 2" Accessory Receiver
2: Rear D-Rings – These are Air Lift Rated
10 Year Warranty on Chassis
Any color your need is available and included with the base model. All we need is your manufacturers color code.
Available Options;
22 Gallon Water Tank – mounts under cargo bed with Armor Housing and Line-X coating - $650
Water Pump – Included with Tank
Full Length Aluminum Folding Galley Table - $350
All Stainless Drop-In Propane Cooktop $250
Sink Basin with Hot and Cold Running Water - $300
Propane System – Includes Mounts, Aluminum Cover with Line-X Coating – 20LB Tank – All Stainless Mess covered lines - $250
Water Heater - $400
Shower Privacy Enclosure - $150
Latrine with Enclosure - $150
Elevating Cargo Rack System - $1595. $1500 if ordered with trailer.
Roof Top Tents – From $995 - $3500 depending on model.
Awning 78ft - ARB 8ft Model 2500 - $250
Dual Articulating Solar Mount with 2 Goal Zero Bolder 30 Panels - $750
Steven McKenzie
Madison, WI
2013 E350 EB-44, V10 6.8ltr
Toyo LT285/70 R17
