Re: Trailer build on 170mm lug pattern
4x6 tire theory: Having the rig run on identical tires gives me a few more options. I can relegate older tires on the van to trailer duty where they lasts practically forever. Or, budget permitting I could buy 6 new tires and rotate across six hubs. The small trailer definitely behaves better with larger tires. And of course theres a bit more curb appeal.
As for the escape plan(s), i personally have never blown two tires on the same trip. So I'll take my chances with one spare for 90% of my travels. Come Baja time, sure I'll add a second spare. Its sitting in the shed, as I do loan out the trailer and they need to have it on the trailer. Even a 31" tire can take up alot of space in a trailer box. I may make a mount underneath after all the other stuff gets placed.
Leaving the trailer is a no brainer if there's no other choice. Its insured, has a big-ass lock/chain, and I can transfer anything of value to the van. It has crossed my brain to acquire a gps transmitter that could be left on a trailer during the day when out exploring or fetching a repaired tire. I might even tuck my SPOT atop the RTT if I thought there was zombies near by.
Mario at AT did see the trailer at his last BBQ (july 2011). The frame is 2x3 which is his choice, and thought he could wiggle his indy-arm system around the 16 gallon water tank that sits above the axle now. His suspension would double the value of the entire trailer, and for now I want to explore some DIY alternatives. For my travels, the straight axle is plenty functional. Sadly, my good friend just bought a slightly-used Horizon that was loaded. Mario is getting his jeep and trailer to mate properly this week. I may suffer from suspension-envy and be forced into playing along.
For now, I am thinking I'll buy the 8x6.5" hubs and have an axle made. At under 1000 lbs, I'm not concerned that the axle even have any camber.
If anyone has done similar, would appreciate all insight.
Phoenix Arizona
2008 E-150 5.4L w/Quigley. Vangator II Wheelchair lift,
