Old 11-20-2016, 03:08 PM   #1
1der's Avatar
03+ E Series Power Tow Mirrors
Hey All,
I have six sets of the cool OEM FORD (not aftermarket) telescoping power mirrors I came across in my pursuing of stuff!
These are very good condition USED mirrors. I have checked each of them for power function and they work smoothly. The plastic housing has been cleaned and treated with 303 Aerospace UV Protectant. There are, imho, some minor scratches/ fading and these pictures probably look a bit better than real life. E.g - note the driver side mirror pic shows some fading on the upper extension bar.
ID:	13922Click image for larger version
ID:	13923Click image for larger version
They come with the nuts and washers that secure the mirror to the door, these may not be factory as some were missing. I will include washers and nuts with each mirror.
Price per set of Driver and Passenger is $115 plus shipping. These weigh 25 lbs. I have an account with FedEx Ground, so it cost less than rack rate to ship. Residential delivery estimates are $13 nearby to $35 across the country. These are shipping from San Francisco.
I know there will be questions around what years these will fit. I have some info from first hand experience. Let me know if any other questions!
Thxs! Ray
FITMENT:
I know they were plug and play on our 2003 E350 XLT, and some here have installed them on later years with little to no mods. Sometimes two wiring pins need to be reversed (very easy to do) in the connector to determine the correct movement of the mirror when the directional switch is operated.
They are NOT plug and play on a 2002 and prior. The doors are definitely different on 2003 and up. It is easy to tell the difference by pulling the inside trim cap at the leading edge of the window covering the mounting nuts. The 2002 and prior are secured to the outer skin of the door, the 2003 has the nuts securing against the inner metal panel of the door. Can the 2002 and earlier doors be modified to accept these tow mirrors? The answer is a definite "maybe", some else who has done this can chime in. Toi me it looked like more than just drilling one more hole, or cutting one mirror stud off. At least on a 2000 van the holes on a 2000 van I looked at, it would require enlarging two existing holes and drilling two new holes. Then figuring the securing of the mirror would have to be figured out. The connector wiring would be an easy modification. I was going to put a set on our 2002 van, and may still do it, but it is more entailed than I want right now. Here are some pics of 2000 van door:
OUTSIDE SHOT 2000 van door, note the mirror stud length, it is much shorter than what is on the tow mirrors;
FROM INSIDE 2000 van door, nuts locate in the recessed holes
Old 11-20-2016, 03:16 PM   #2
A HUGE improvement when I installed them on my SMB. GLWS.
Old 11-20-2016, 04:10 PM   #3
I'll take a pair. My zip is 97330 (residential). I almost stopped by the wrecking yard yesterday, because my current motors are toast. Since I have some on now (aftermarket pair) I've already done the conversion.
FWIW, using a stepped "uni-bit", or cone shaped drill bit, make the mod easy, using the foam gasket as a template. Then just match similar colors together on the wiring (i.e. yellow to orange, blue to purple. The other two were the same).
Old 11-20-2016, 06:05 PM   #4
PM sent..........
Old 11-20-2016, 06:12 PM   #5
ShuttlePilot's Avatar
PM also sent. He did say six pairs, right?
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 11-20-2016, 06:29 PM   #6
damn all i need is power for the power mirrors on my van lol
polishadam82 is offline   Reply With Quote
Old 11-20-2016, 07:27 PM   #7
6 pairs Ray? You're a van hoarder!!!
Old 11-20-2016, 08:39 PM   #8
WhitH's Avatar
I'll offer to be a runner if anybody in Oregon wants to wait and not pay shipping. I'll be heading down to SF in December or January and can bring them back up to Eugene or then Portland.
Sold 2005 E350 Chateau
Old 11-20-2016, 09:51 PM   #9
freeagent's Avatar
I would like to take a pair off your hands. PM sent!
2005 E350 4x4 V10
freeagent is offline   Reply With Quote
Old 11-21-2016, 12:03 AM   #10
I'm interested. PM sent.
2006 Ford E-350 6.0
Czar308 is offline   Reply With Quote
