Old 09-09-2018, 12:51 PM   #11
Bellpilot's Avatar
I have a set of these off a 2001 E350 with the caps I would be glad to part with. I would imagine shipping would be pricey from Bend, Or.
2010 E350 6.0 4x4 EB 50 SMB
Old 02-05-2024, 07:43 PM   #12
Do these use special lug nuts?
These Alcoa style rims, do they use acorn lug nuts, or washer style? I got a set of 5 with center caps. There are marks on the rims where you can tell washer style lug nuts were used, but there is also a female acorn taper to each hole. I got them at a junk yard void of the donor vehicle and the original lug nuts. So IDK what nutz are best.
PeterHolmbeck is offline   Reply With Quote
Old 02-05-2024, 07:51 PM   #13
Bellpilot's Avatar
Man, it has been a while but I think they had washers with a tapered threaded end.
Old 02-05-2024, 07:59 PM   #14
Bellpilot's Avatar
Look liked these if I remember
Old 02-05-2024, 08:29 PM   #15
I have a set of these on my van. The taper in the hole indicates they are lug-centric and take the standard conical nut. This is the same as for factory steel wheels. Nothing decorative is needed as the nuts aren't visible under the center cap.
Turtle
rafeman
Behemoth
Besags
