Old 06-04-2011, 06:13 PM   #1
2006 E350 SMB RB-50 Diesel "SOLD"
Meticulously cared for, exceptionally clean (like new), serviced every 5k, washed after each use, always garaged. You will not find a cleaner Sportsmobile unless its new. Zero leaks anywhere, mechanically perfect. Drives, shifts, stops, handles like new. Average MPG since new 15.1, best 18.7
Asking $74,500
Located in Livermore, CA Call Brad @ 925-784-6349 cell up to 9pm PST
Email : bradjcaroline@msn.com
Additional pictures located in my gallery….bj9212
2006 E350 Sportsmobile
Original owner
All documentation since new
55,791 miles
6.0 diesel engine
4.10 limited slip rear end
Sportsmobile 4x4, Pro-rock front end, Atlas transfer case, sway-bar disconnect
RB-50 plan, seats 5, sleeps 4
Penthouse w/bed
Baja Tan exterior color
FORD PREMIUM CARE Extended Service Plan good through 8/17/2014 or 96,460 miles, transferable to new owner, look up the Premium Package on Fords ESP site for complete details. This is the best most comprehensive plan available.
46 gallon extended range replacement fuel tank
Quigley oil filter mount. Same location as factory, but turns filter horizontal. Moves filter approx. 3 inches away from SMB front drive shaft. (Originally within ½”, could get knocked off)
ESPAR Airtronic diesel heater
2 Solara walk-on solar panels
Inverter 2000 w/Trip –lite & solar controller
Aluminum Baja Wheels
New BFG LT285/75R-16 E rated tires at 40,000 miles
Firestone Rear Airbags with remote fill valves at rear bumper
Trailer tow package
Fiamma F45 awning
ATS running boards
Aluminess swing away spare tire carrier
Custom made clamp-on flag pole holder w/flag pole and new flag(clamps to diagonal spare tire brace and swings with spare tire)
Aluminess rear ladder
Everblades heated windshield wipers and wiper frames(never have ice/snow build-up again)
Yakima rack, 2 cross bars
Marinco stainless steel utility hook-ups(power, water & cable tv)
2 red top Optima chassis batteries
Heated leather driver and passenger seats, power drivers seat
3000 miles on Rancho 9000 adjustable shocks
Engine block heater
Custom made computer/lunch tray swivel mount between front seats(removes in less that three seconds)
Marine deck vinyl w/carpet overlay
XL 8 cu. Ft. under floor storage, line-x coated
Cloth gaucho seating
10 gallon fresh water tank
2.5 cu. Norcold refrigerator (approx 2 years old)
Microwave
Porta potti
Medium window tint w/ day night pull down shades
Rear shower
CB radio w/k-40 antenna
Scanguage 2 with complete list of 2006 Ford trouble codes/definitions
12” overhead swivel tv w/dvd player under gaucho seat
Premium Kenwood in dash stereo(disappears when off), IPOD adapter, updated speakers-5
Hood bug deflector
Bushwacker flares
Extra 12v and 110 volts plugs throughout
Extra parts included(all new): upper & lower radiator hoses, all other misc coolant hoses, serpentine belt, fuel filter, transmission filter, air filter, oil filter & socket , front and rear u-joints, front and rear wheel bearings/races
bj9212 is offline   Reply With Quote
Old 06-04-2011, 08:19 PM   #2
Re: 2006 E350 SMB RB-50 Diesel
Wow, highest gallery photo to post ratio ever! And to think I was going to ask to see more pictures.
I like the 3 ports on the side instead of the propane door- what are they? Electrical, city water, and ??
Edit: found em-
Old 06-04-2011, 10:23 PM   #3
cellularSTEVE's Avatar
Price?
Old 06-05-2011, 08:17 AM   #4
I guess that would help. Asking $74,500.
Price now in ad.
Thanks,
Brad
Old 06-11-2011, 10:02 AM   #5
I notice that you have the rear shower but there is no mention of a hot water heater. Is there a hot water tank and heater or does the shower just flow cold?
Thanks,
Gus
canyonrover is offline   Reply With Quote
Old 06-12-2011, 11:50 AM   #6
Gus,
Originally the van had a flat plate heat exchanger when new, but a cold -16 degree day in Bryce Utah split the exchanger. I had the exchanger removed and returned to original factory Ford condition. We actually never used the hot water and wish I had saved the money at purchase. When the van is warm inside so is the water, so I didn't mind taking 75+ degree showers. Anything hotter in small quantities we would use our Jetboil.
Thanks,
Brad
Old 06-12-2011, 12:57 PM   #7
Thanks for the information on the hot water. I noticed a bit of rust on the drivetrain. The rest of the truck looks immaculate. Is this just from normal wear and tear and actually keeping the drivetrain clear of grease and grime? Do you spend time where they salt the roads? Again, thanks for the information. This is one super SMB.
Gus
Old 06-12-2011, 03:20 PM   #8
We visit the coast for sure but don't spend enough time there for problem rust. What you see is just what happens under every vehicle I ever owned out here in California. Certainly not a problem, just what happen to a factory paint job(drivetrain only).
Thanks,
Brad
Old 06-12-2011, 03:22 PM   #9
Oh yeah, forntunately Caltrans does not use salt in CA.
Betsy
darryldickie
Ford
fabtechmfg
