Old 07-07-2012, 08:15 PM   #1
2011 U Joint Offroad 4X4 E350 Super Duty Extended
Hi All, here is a 2011 E350 4X4 Extended Cargo Super Duty with a 5.4L V8 just built. The van has a slider with no glass, no glass in rear barn doors. It was just built, it has 3K miles and the following features:
6" lift in front, 8" in rear (all suspension no blocks) it was designed with extra rear ride height
F550 brakes with ABS
Dynatrac front axle with Warn hubs / with RSC
80 lb Toyo tires work with standard Ford TPS
Dynatrac front and rear differential covers
Black powder coated front and rear factory bumpers
Black factory grille
Factory Ford forged aluminum 8X170 wheels
The truck is absolutely prisitine, and has been clay bar waxed to mirror shine from the roof down. The interior is a standard cargo with optional Ford rubber mat.
The truck has never been used off road, and is ready for whatever interior you wish, i.e. cargo work, or camper.
All the work was done by U Joint Offroad, which only use proprietary leaf spring systems for four wheel drive conversions. The van drives wonderful, straight, and is really incredible to look at.
This van is unbelievable and virtually brand new, I hate to have to sell it. $44K 201 747 0977
stevegermano is offline   Reply With Quote
Old 07-09-2012, 01:17 AM   #2
BIGVANS's Avatar
Re: Just Built UJO 4WD E350 Super Duty
Ahhhhh..........., Nothing like a fresh, clean canvas to work with! Congratulations!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 07-09-2012, 08:35 AM   #3
Pntyrmvr's Avatar
Hi;
The front driveshaft appears to be missing in the photo. Can we assume that it is now installed?
EDIT- I don't see a shifter for the transfer case either. Did the ad say 4x4?
Regards,
Gavin
Old 07-09-2012, 09:34 AM   #4
@ Gavin,
Good eye, the deal includes the gears of your choice, driveshaft, and transfer case. The Dynatrac axle, F550 brakes with ABS/RSC/TPS is extra heavy duty and really put together well.
Call me if you want to discuss gears or such.
Steve
Old 07-09-2012, 09:45 AM   #5
Ultrasport12's Avatar
Nice van,someone will want it...
Good Luck on the sale...
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 07-09-2012, 10:19 AM   #6
Thank you, its a good looking strong van that rides really well and steers poker straight even at 85 + mph. Chris at UJOINT built it, and knows what he is doing.
