In excellent condition, used four times.
From Coleman:
- Hot water dispenses from the faucet in less than five seconds, adjustable up to 160° F
- Full size faucet fold into handle
- Heat up to 40 gallons of water with one compact Coleman® 16.4 oz. propane cylinder (Propane sold separately)
- Water flow is 1 gallon per minute on the warm and cool settings. It is about 1/2 gallon per minute on the hot setting
- For even more hot water, adapt to a bulk propane tank (adapters and tank sold separately)
- Rechargeable 6-volt battery pumps the water
- Battery can be recharged in the car or off of a household outlet
- Recharge cords store inside the heater
- Simple to maintain: clean the heater with a simple household solution
- Portable, propane hot water system for outdoor use only
- Great for emergency preparedness
- 3-year limited warranty
- Dimensions: 17 x 9.6 x 16.1 in.
Comes with carrying case and shower wand, as well as custom attachments to adapt the water pick up to a 5 to 7 gallon water jug. The cool thing about the adapter is it will recycle the hot water into the jug to conserve fuel and provide hot water nearly right away to avoid the water in the tube going cold while soaping up!
Uses standard 16 oz propane bottles. This unit receives excellent reviews!
$220 plus shipping. It weighs about 30 lbs.
