Old 07-18-2018, 04:01 PM   #1
longboardguy's Avatar
FREEBIE: used Quigley non-serviceable hub bearings
I had recently replaced the front unit bearings on my 2006 e350 w/quigley dana 60 front end. I saved the old hubs in case there was someone that wanted a spare or back up part. New hub bearings are $500 ea from Quigley.
I believe these were used on the 1999-2004 F350 4wd front axles. My axle is a 2003 year F350. My e350 van has 155,00 miles, the bearings are original from quigley with the 8 on 6.5 bolt pattern. When I removed them, the bearing were not making any noises or had any slop in them. I cannot make any promises on how much longer they could last, so no guarantees on these at all.
They are free but beer is king. They weigh 26 lbs each. I can ship them if needed but you pay the cost. Local pick up is best. I am located in So. California 92627
Let me know if anyone is interested in these.
longboardguy
2006 e350 EB Quigley V10 Gas Daily Driver
Fiberine 24" high top
Home Build interior, 200w solar, 42 Gal fresh water
46 gal Transferflow tank, Agile RIP kit
longboardguy is offline   Reply With Quote
Old 07-19-2018, 09:19 AM   #2
TomsBeast's Avatar
I delved into unit bearing replacement on my 2001 Dana 60 front axle a couple years ago, one of mine started grumbling and screeching during a 1500 mile trip, luckily at the tail end, about 20miles from home. Being a non-servicable part, there's no roadside fixes, or scrounging
Having a spare on hand, particularly when these are a specialty 'modified for Quigley' deal, seems like a 'must' for anyone with that set up. Either that, or carry a wheel adapter in your spares box, so you can locate a common Ford unit bearing assembly, and adapt the stock 8 on 170mm to 8 on 6.5" van wheel, to get you home.
Old 07-29-2018, 11:43 AM   #3
Tom,
Thanks for the additional info.
The hubs are still available.
Here is a pic of the new ones. The freeebies look the same except they are dirty.
Old 07-31-2018, 01:21 PM   #4
brushogger's Avatar
That's a deal there! It looks like UPS ground to me (73104) would be around $44-45. I'll take one. My SMB is a 2004 Quigley. Is the only difference in the Quigley bearings and stock Ford for those years the lug pattern?. Thanks. I'll PM you
brushogger is offline   Reply With Quote
Old 10-30-2018, 09:17 AM   #5
Just a bump on this thread.
I still have 1 Hub bearing available.
I can pass it along to someone at the next So. Calif. van meet up or ship it out.
It's a Freebie!
Old 08-26-2019, 11:23 AM   #6
Do you still have one of these hubs I am local to you and could pick it up my number is 9093741756 thanks
Warpt is offline   Reply With Quote
Old 08-26-2019, 03:31 PM   #7
Both of the hubs have been claimed and are no longer available.
Betsy
darryldickie
Rufus
LARufus
