Old 09-02-2016, 03:54 PM   #1
FS: 2006 EB50 5.4 gas Like New Only 17,000 miles! $35,900
Missed the chance to buy a new Sportsmobile Ford van before they were discontinued a couple years back? Well, this is the next best thing!
2006 E250 Super Duty 5.4 gas engine EB50 with a true 17,000 miles! It really is like new. Here's the post from the dealer I bought it from: 2006 Ford E250 Sportsmobile Value? - Sportsmobile Forum
It was ordered with a lot of options (Starcool, generator, heater, fridge, micro, stove, etc) and the van has the optional limited slip rear axle (see build data). I'm the second owner. The first was a handicapped individual, and he ordered it without the rear 3 person folding seat/bed gaucho. He was not able to drive it anymore a couple years after delivery and it was only used occasionally by his kids.
Since purchase I removed the handicap equipment and installed a reclinable/foldable three person bench seat in the rear and a single captains chair by the side door to accomodate my kids and parents. These were from a low mileage Ford Windstar van (upholstery matches the van well) and I installed them using the factory mounting hardware. They use factory Ford lap seatbelts. You could have SMB install a gaucho if you want to use the rear as a full size bed, but I prefer the Windstar bench for its greater comfort, recline setting, headrests, and car seat LATCH points. My kids were small enough to use the rear bed without the gaucho extension.
I also upgraded the wheels to OE Ford forged alloys with new tires. The van had the original dry rotted 2006 dated tires on it when I bought it with lots of tread still! The van runs, drives, and even smells like new. I've put 5000 miles on it this past year with zero problems. All camping equipment works as it should. Both A/C systems blow ice cold, Generator has less than 1 hour on the clock. Body is excellent, all original paint with no dents or dings. Poptop canvas, windows, and screens are like new.
I‘m selling because I just bought another 2006 SMB...a diesel E350 short body which will better suit me for a daily driver. If you spec this van out at the SMB Website (using a Chevy van) it would cost close to $100,000. Asking $38,900. Located in Loma Linda, CA, about 1 hour from LAX.
Check back often...I will take more pics this weekend.
Poptopper is offline   Reply With Quote
Old 09-02-2016, 04:18 PM   #2
Uploading photos here is time consuming...I will put together a photo gallery this weekend.
13320010_10154245302809766_5988849131461767579_n.jpg   IMG_9103.jpg   IMG_9101.jpg   11781648_1490603547922302_6414230517765414317_n.jpg
Old 09-02-2016, 04:26 PM   #3
SMB features:
Bed 6' 6" (78") X 39 1/2"
Microwave: Dometic cdmw07w
Stove: Wedgewood Vision DV series MPD56283
Heater: NT-20S
AC: starcool
Fridge: norcold
Genset: Onan Microlite 2800 series
Ford Build sheet:
Build Date:
27.03.2006
Vehicle Line:
Econoline
Body Style:
Extended Van
Version:
250 Series Super Duty
Engine:
5.4L Modular SOHC V8
Transmission:
4 Speed Automatic 4R75E Livonia
Drive:
LHD RWD
Axle Ratio:
3.73
Emission:
50 State Emission Requirements
Air Conditioning:
Manual Air Conditioning
Territory:
(+)"USA"
Paint:
Oxford White
Minor Features
- Medium Flint interior
- Untrimmed
- With RH Hinged Side Load Door
- With Front Passenger Door
- 138"/3505MM Wheelbase
- RV Prep Version
- Ohio Assembly Plant Build
- U.S. Sales
- Less Special Equipment Package
- 8600 LB. GVW
- Less Military Vehicles
- Less Exterior Appearance Pack
- With Functional Upgrade Pack
- With Power Equipment Group
- Less Ambient Temp/Speed Pack
- Less RV Conversion Upgrade A
- 2006 Job #2 Program Control
- Less Electronic Stability Control
- Less Utility Package
- Less Premium Group
- With English Language Label
- Owner Hand Book Pack
- Less Certification Label
- With Med Duty Pass Vehicle Configur
- With 2 Ton Mechanical Jack
- With Power Front Windows
- Less Rear Quarter Window
- With Tinted Glass
- With RH 2nd Row Fixed Window
- Less 2nd Row LH Side Window
- Less 3rd Row RH Side Window
- Less 3rd Row LH Side Window
- Less 4th Row RH Side Window
- Less 4th Row LH Side Window
- With Fixed Rear Window
- Less Overhead Console
- Console-Slimline 2
- Less Rear Compartment Trim Panel
- With Base Interior Decor
- Less Front Floor Mats
- Less Passenger Floor Covering
- Less Headlining
- With Illuminated Sunvisor - Drivers
- With Illuminated Sunvisor-Passenger
- With Level 2 Door Trim Panel
- Less Quarter Trim Panel
- Less Cargo Stowage Rack/Rail
- With Sound Insulation Pack Level 1
- Less Running Boards
- Chrome-Plated
- With Dipping Rear View Mirror
- Dual Sail Mtd Power Mirrors
- Less Centre Asle ST Prep Pack
- Less 2nd Row Rear Seat
- Less 3rd Row Rear Seat
- Less 4th Row Rear Seat
- Less Fifth Row Seating
- With 2 Seat Configuration
- With Driver 2 Way Mnl. Seat Adjust
- With Pass 2 Way Manual Seat Adjust
- With Heavy Duty Trailer Towing
- With Trailer Towing Hitch
- Less Engine Oil Cooler
- Extended Van
- With Central Locking System
- With Door Entry Remote Control Unit
- Less Body Tu-Tone Paint
- Front Bumper - Steel Chromed
- Rear Bumper - Steel Chromed
- With Front Licence Plate Bracket
- With Driver Air Bag
- With Passenger Air Bag
- With Exterior Tyre Carrier
- Less Frame Spacer
- Less Frame Fastners
- With Steel Spare Wheel
- With Single Rear Wheels
- 7 X 16" Steel Road Wheel
- Spare Tyre - LT225/75R16E
- With Sport Wheel Cover
- Less Immersion Heater
- 50 State Emission Requirements
- With Handling Package
- Front Axle Rating-Normal
- 3.73
- Rear Axle Limited Slip Differential
- With Dana Axle
- 5520 LB Rear Axle Assy
- 5.4L Modular SOHC V8
- With 4 Wheel Disc-Brake
- Normal Fuel Fill
- With Standard Transmissn Oil Cooler
- Less Clean Fuel Fleet Vehicle
- With Auxiliary Fuel Ports
- With Mid-Ship Fuel Tank
- Non Locking Fuel Cap With BP Label
- For Unleaded Fuel
- With Tilt Steering Wheel
- Basic Type Steering Wheel
- With Speed Control
- Less Auxiliary Heater
- Less Heater/Air Con Prep Pack
- With MPH/KMH Speedometer
- Single Note Electric Horn
- With Key In Ignition Warning Chimes
- Heavy Duty Battery
- Less Auxiliary Batteries
- Heavy Duty Alternator
- With AM/FM CD Player
- Less Radio Pre-Equipment Pack
- With NAAO Radio Frequency
- With 6 Speakers
- With Daytime Running Lamps
- With Aero Headlamps
- With Light Group
- With High Mounted Stop Lamp
- With Rear Courtesy Light Switch
- Oxford White
- Generic Country Group 1
- 250 Series
- 3C24 5310 LA Left Front Coil
- 3C24 5310 LA Right Front Coil
- 5C24-5560-RA Left/Rear Leaf
- 5C24-5560-RA Right/Rear Leaf
- Less B&A Control Codes Issue 030388
- Less LPO 50S Emiss Calib Label
- 4 Speed Automatic 4R75E Livonia
- Econoline
- Less Fleet
Old 09-02-2016, 04:28 PM   #4
Nice looking van Poptopper!
Calling RallyPanAm, here is another one of those Full Frame Awning style windows you were curious about. Maybe Poptopper's build sheet has some info?
Old 09-02-2016, 05:58 PM   #5
simplesez's Avatar
Cool. Looks a lot like ours!
Old 09-04-2016, 02:31 PM   #6
Thanks for the compliments! Yeah, I've never see another awning window like this on an SMB...must be a special request.
No inquiries yet, so I went ahead and listed it on eBay classifieds. Please call or text me at (909) FIVE83-1894 if you are interested. Lots more photos there:
2006 Sportsmobile EB50 Ford 5 4 Gas Like New Only 17 000 Miles | eBay
Old 09-04-2016, 03:44 PM   #7
rallypanam's Avatar
Originally Posted by Ben10281 View Post
Calling RallyPanAm
Sadly they won't work. Hehr 30x17, which is slightly too small to replace my crappy CRL 32x18.
Old 09-10-2016, 10:41 PM   #8
Had a lot of inquiries but nobody has come to see it yet.
Price drop to $35,900.
Old 09-12-2016, 07:17 AM   #9
Hi - curious about the back bench. Have you checked into adding shoulder straps? My kids are outgrowing child seats and I'm trying to find a SMB with forward facing shoulder straps. The other, related question, is how comfortable is the bed in back for 2 6' adults? Do you have a pad that fits over the folded-down bench?
Thanks!
lashito is offline   Reply With Quote
Old 09-16-2016, 03:12 PM   #10
My kids still used car seats, so the LATCH mount points were my main concern. The E vans do have mount points on the walls (behind the SMB side panels) for shoulder belts.
The rear bed was setup for our two small children, so we did not bother with a pad that stretches across the bench, but it could definitely be done. There's enough room for a 7 ft. 2 inch bed to fit.
