Gently used Xantrex LinkPRO Battery Monitor: (Photos attached)
The LinkPRO selectively displays voltage, charge and discharge current, consumed amp hours, remaining battery capacity and the time remaining of your battery bank. It is equipped with an internal programmable alarm relay, to run a generator when needed or to turn off devices when the battery voltage exceeds programmable boundaries.
Highlights:
-Read your battery bank like a fuel gauge
-Provides critical information about the status of your battery bank
-Displays voltage, current, consumed ah and remaining battery capacity
-Secondary battery bank voltage monitoring
-Auto sensing battery voltage inputs
-Large backlit LCD Display
-Quick nut mounting construction
-Programmable alarm relay
-Shunt selection capability enables flexible system integration
-Splash proof front panel
-500 Amp shunt included
-Stores a wide range of history events in internal memory
-Advanced programmable alarm relay
-Battery temperature sensor input
Full details here:
Battery Chargers | LinkPRO Battery Monitor | Xantrex
