Old 01-01-2015, 02:04 PM   #1
MrHenrietta's Avatar
ISO: Busherwacker Fender Flare Gaskets
Looking for the black gasket liner. Enough for 2 flares.
Cheers
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 01-01-2015, 07:07 PM   #2
Jeffrey's Avatar
Re: ISO: Busherwacker Fender Flare Gaskets
I don't think that material is a propriatary shape for Bushwacker. You can probably that rubber edging or similar at McMaster Carr.
Old 01-01-2015, 10:12 PM   #3
I'm trying to think of an application that uses that thin flat rubber, like intertube rubber but in a big flat piece you could cut your own from. I'm sure there are non-vehicle applications but I can't think of any at the moment.
Then again if you cut from the flat of the torus on a good sized intertube (pink line in image) you might be able to get a nice flat piece to match your flare.
Old 01-01-2015, 10:47 PM   #4
Tried contacting bushwacker?
Old 01-02-2015, 09:40 AM   #5
Jeffrey's Avatar
Jeramiah, I don't believe the strip is flat. It is an extruded shape with a slot along one side to accept the plastic flare edge.
Old 01-02-2015, 10:42 AM   #6
Yeah I actually ordered the wrong one by accident from bushwhacker which I'll now be returning. It was like $40 with shipping so I figured I check to see if anyone has any extra for cheaper before reordering.
Old 01-02-2015, 05:59 PM   #7
JackTuppVan's Avatar
Summit has the bushwacker gaskets same part number as listed on the bushwacker site for front or rear flares for 1999 Ford Econoline (summit price 30 foot roll - $27.) . Bushwacker P/N 000045-01 Summit P/N BSH 000045-01 (fender flare trim / gimp) link...http://www.summitracing.com/parts/bsh-0 ... MgodBA0AnQ hope this helps
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 01-02-2015, 06:06 PM   #8
I forgot to add the bushwacker link for comparison . Look under tab replacment parts . http://www.bushwacker.com/fender-flares ... r-22003-11
Old 01-02-2015, 06:56 PM   #9
Ah, ok. My van is under a huge pile of snow at the moment so I didn't go look
