Old 03-18-2015, 11:46 AM   #1
ISO: Dana 60 Ring and Pinion 3.73 gears
Hi there,
Im looking for r&p gears for a dana 60 that are 3.73
I figure someone here has done a gear change to 4.10 or higher and has a set that they might want to part with.
Thanks!
-JJ
Jjjewett is offline   Reply With Quote
Old 03-18-2015, 12:57 PM   #2
Re: ISO: Dana 60 Ring and Pinion 3.73 gears
When I had 411's put in my van, the shop removed the old pinion gear with a sledge hammer, totally ruining the gear. When I inquired about this I was told that some times they get stuck and need to be pounded out. My factory manual says there is a tool for this, but the shop obvously took the quicker route. It's possible this was the front Dana 44 though and I may have a good rear gear set, but I won't be back to check for quite a while. (months) If you don't find one, keep posting and I'll check when I get back. If I do have one, it's yours for the cost of shipping.....................
Old 03-18-2015, 01:00 PM   #3
schluchtenflitzer's Avatar
Originally Posted by Jjjewett
Hi there,
Thanks!
-JJ
i have some in very good condition
also have a brand new airlocker (yukon zip locker for 4.56 up)
used open differential (4.1 down)
all 35spline
but i am located in germany
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 03-18-2015, 02:14 PM   #4
E350's Avatar
OT: schluchtenflitzer: Did you see the thread on vacuum pump? Make sure you take a spare serpentine belt driven vacuum pump with you on your African trip. (My last one was made in Bulgaria so just take a little Eastern detour on the way to Gibraltar and pick one up.)
Old 03-18-2015, 04:10 PM   #5
Thanks E350 the actual plan is to go the eastern way via Turky, Iran, Saudi Arabia, Egypt, Sudan, Ethiopia...... so Bulgaria is on the way to get to Turky. Hope i have free room than for it
Old 03-19-2015, 09:55 AM   #6
Thanks guys. Still looking.
Old 03-19-2015, 12:19 PM   #7
OP, have you considered going new. I mean for the cost of the labor (+$200 unless you are doing it yourself) you can get a Dana Spicer ring and pinion with the gearing you want from RockAuto for ~$300.
Is it worth taking the chance installing used gears to save some money now when it might end up being a more expensive repair down the road in some place inconvenient. Just say'n.
2011 VW TDI Golf for hwy fun
Old 03-19-2015, 04:33 PM   #8
chetubi's Avatar
Mine were changed to 4.30 right now by John @ quadvan.
I do not know about the condition. And I do not know what John intends to do with it.
But perhaps it is worth giving him a call.
Philipp
'08 Ford e350 Sportsmobile
'07 Toyota FJ Cruiser
'10 Lada Niva
'04 Nissan 350Z
'67 Alfa Romeo Giulia
chetubi is offline   Reply With Quote
Old 03-20-2015, 12:54 AM   #9
BajaSportsmobile's Avatar
I have several sets - you can have one.
AgileOffRoad.com
Old 04-27-2015, 10:44 PM   #10
Huge thanks to BajaSportsmobile!
This is a great forum.
-JJ
