Old 09-26-2017, 07:12 AM   #1
Kyocera KD140XLPU -12 volt solar module
This is a used, was previously purchased and installed in 2012. I don't want to ship so some one local to the Portland area would be great. I am asking $50.00.
picture of it installed:
[IMG][/IMG]
Specifications:
Max Rated Power (Pmax) 140 Watts
Voltage at Max Power (Vmpp) 17.7 Volts
Current at Max Power (Impp) 7.91 Amps
Open Circuit Voltage (Voc) 22.1 Volts
Short Circuit Current (Isc) 8.68 Amps
Length x Width x Depth (inches) 59.06 x 26.3 x 1.8
Weight of Panel (Pounds) 28.4
Connector Cable Type MC4 Latching Cables
Applications:
Residential grid tie systems
Large commercial grid tie systems
Water pumping systems
High voltage stand alone systems
RV systems
12 volt battery charging systems
Warranty:
10 year limited warranty on material and workmanship
25 year limited warranty on power output
Old 09-26-2017, 08:39 AM   #2
Hi Greg -
I'm in SoCal - so I'm not your buyer... but I'm curious.
Are you deleting solar or replacing it with something else ??
Steve W
SteveW is offline   Reply With Quote
Old 09-26-2017, 08:52 AM   #3
Steve,
I replaced the single panel with two newer panels, you can reference in this thread. http://www.sportsmobileforum.com/for...acks-8900.html
Nothing wrong with the panel but, one of the newer grape panels is slightly smaller and puts out 180 watts to the 140 watt Kyocera, That and the slight voltage mismatch made me just jump to two new panels.
Old 09-26-2017, 09:04 AM   #4
Steve,
Any chance you are going to Descend on Bend the first weekend of October? If you are are I would be interested. I also have a feeler out to see if anyone would be willing to bring it to DOB for me.
2006 EB Transformer
scummy is offline   Reply With Quote
Old 09-26-2017, 09:18 AM   #5
Sorry, I am not going to Descend on Bend.
Old 09-26-2017, 09:32 AM   #6
Thanks. Looks like I have a 130 W Kyocera and would end up with a mismatch. Great deal for whoever picks this up.
2006 EB Transformer
Old 09-28-2017, 05:38 PM   #7
I’d be interested in the panel. Will send a DM
1998 Adventurewagen quigley v10
1994 e250 hightop action van lift on 33's (sold)
Yeahbud is offline   Reply With Quote
Old 09-29-2017, 06:33 AM   #8
Sold;
