Old 03-31-2017, 11:56 AM   #1
chrisbaffico's Avatar
More Garage items
Deep Cycle Battery Monitor System
For sale is a new Bogart Engineering TM 2025 RV Trimetric Battery monitoring system intended to help maintain battery systems for 12V to 48V deep cycle battery systems, such as ones found in RVs or off grid homes which are regularly charged and discharged. The amps or watts display measures the rate of energy going in or out of your batteries so you can check your charging systems, and also to see how much energy each of your appliances use to help you conserve energy. The % Full display will help you keep track of how charged or discharged your batteries are. The volts display will let you discover if your charging systems are charging to the proper voltage, which is important for maximizing your battery life. The days since charged display shows how recently the main battery (system) was fully charged, so if it hasn't been charged recently you can perform extra charging if necessary to help maintain the capacity of your batteries. The TM-2025 also can measure the voltage only of a second battery set, such as the starting battery, or solar voltage input to a charge controller. This is kit includes a wiring harness for easy install, a 500 amp shunt and installation instructions. This kit normally runs over $200. $175 plus shipping
Coleman 55 Watt Solar 12-Volt Power Generator Kit
For sale is a Coleman (Sunforce) 55 Watt Solar system Item #: 390910 Model #: 58050 currently sells for $229 at Sam's Club.
Perfect for cabins, recreational vehicles, remote power, back-up power or 12V battery charging. Used briefly with my van but I have mounted a permanent system and have no need for this portable unit.
Specifications
Works with 12V and 110V appliances and electronics with included power inverter
Amorphous solar technology allows the panel to operate in all daylight conditions, even on cloudy days
Fully weatherproof design
Made with a durable metal frame and shatterproof tempered glass
Kit includes: 3 x solar panels, metal frame with stand, 7-Amp charge controller, 300-Watt inverter with USB port and connector cables, 3-in-1 cable connector, wire adapter, 12ft. (3.6m) extension cable, LED voltage tester
Charges 12-Volt DC batteries (sold separately)
Maximum output: 55 Watts, 3.7 Amps
$100 plus shipping and insurance if desired
Dana 30 Z Bent Steering Drag Link
For sale is an MIT built Z-Bent chromoly steering drag link and tie rod assembly used to minimize poor steering characteristics and bump steer when running a SOA (spring over axle) lift in excess of 4-6". Set up for a Dana 30 Jeep axle (includes Z-Bent drag link, tie rod, tie rod ends and steering stabilizer hardware). A must for Spring Over Axle suspensions. $50 plus shipping
Camper Electric Jack Lift Motors
For sale are two Electric Jack lift motors in working condition for a camper. Does not include Jack stands. Can also be use for a slide on a trailer. Not sure of the rating or application. $50 plus shipping
LED Light Bar Brackets / Mounts
For sale are a pair of GS Power LED light bar mounting brackets for 1.75" - 2" tubing. They are aluminum with a matte black powder coat finish. Never used. $25 plus shipping
1999 Ford E350 EB PH
7.3L V8 Powerstroke Diesel
Custom flr plan like EB44
Agile Offroad 4x4
chrisbaffico is offline   Reply With Quote
Old 03-31-2017, 12:04 PM   #2
rallypanam's Avatar
I'll take the solar setup, pending quote on shipping to 94110.. hopefully it's not crazy high.
