Old 03-01-2016, 03:34 PM   #21
rockbender's Avatar
Originally Posted by 4liner View Post
That block that you are referring to is attached to the bed. It is 1.5 x 2.75".
The bed is 39.5" wide.
THAT is why it doesn't fit in the Ford! All of the other penthouse beds I've seen have the plywood base sitting directly on the angle frame. You effectively have nearly an 8" thick bed with those rails attached.
Josh
Old 03-08-2016, 09:44 PM   #22
Our sprinter bed came with the "lift kit" or rails under the flat bottom.
Onefin is offline   Reply With Quote
Old 03-08-2016, 09:49 PM   #23
Bed photo
Bad picture, but I think you can see the rails screwed directly into the ugly "whiteboard" on the bottom of the bed.
Old 03-09-2016, 07:14 AM   #24
Apparently the Sprinter PH bed doesn't fit the Ford.
....Still for sale. Heading to Pasadena for a week or so in case anyone in So Cal is interested in it.
4liner is offline   Reply With Quote
Old 03-09-2016, 09:22 AM   #25
Try listing on San Diego, Orange County, and LA craigslists. Lots of ford SMB vans in the area, maybe someone needs one?
Goognlck with sale.
"Ford sportsmobile 4x4 camper van pop top bed" should hit most keyword title searches.
Old 03-09-2016, 01:40 PM   #26
Hi if this is still available I'll take it, if you will be near San Diego any time soon.
SteveAndLillian is offline   Reply With Quote
Old 03-09-2016, 01:45 PM   #27
This one won't fit a Ford SMB without some rework/upholstery work.....
Old 03-12-2016, 10:17 PM   #28
PM just sent
WACOOR is offline   Reply With Quote
Old 01-26-2020, 12:21 PM   #29
Just to update this very old thread, I ended up keeping the bed. Have one more trip to make from TX to AZ and then I'll be listing the Sprinter in the For Sale section in about another month.
