Old 07-25-2018, 11:57 AM   #1
Powerstop rear rotors and pads
I bought a set of drilled and slotted Powerstop rotors from Summit Racing for the rear of my 2001 E250, (Dana 60, 8 on 6.5in lug pattern) but they rusted out within a couple months. Summit refused to provide any relief, saying they only warranted against rust for 30 days. When I called Powerstop directly, they admitted there was a problem with the metallurgy in some Chinese sourced rotor blanks. They offered to immediately send a replacement set, but I didn't want another set of the same model as they too could have been defective, so they offered a different type of rotor that was coated to prevent rust, but that weren't slotted or drilled. The problem was, they were sourced from Germany and wouldn't be in stock for a couple months, so I had to buy a set of stock rotors from my local auto parts store. Two months later, the replacement set showed up, but I doubt I'll ever wear out the set on the van now. So, these are AR8578EVC coated rotors, (the least expensive I found were $75 ea) and come with a set of Z36Extreme / severe duty truck and tow brake pads. ($50 a set a Summit) Follow the link below for application info. I'm open to any reasonable offer, but the rotors are hell of heavy, so I prefer not to ship. Pick up would be in Northern Washington, but I may be able to meet somewhere as I'm on the road a lot.
https://www.adrenalineoffroadandcust...tors/AR8578EVC
Old 07-29-2018, 04:06 PM   #2
Anyone? I need these out of my garage.
Old 07-30-2018, 05:47 PM   #3
REF
REF's Avatar
Send a message via MSN to REF
Sounds like they’d make good boat anchors.....I’ve got a set of original modified front rotors for my Quigley sitting in my garage, that’ll make a full set, someone come and get ‘em
REF is online now   Reply With Quote
Old 07-30-2018, 11:30 PM   #4
These are completely different rotors than the drilled and slotted ones that rusted. These are not drilled or slotted and there coated to prevent rust. If you need a boat anchor, I have several, but these should work much better as real brakes.
Old 07-31-2018, 03:21 AM   #5
REF
REF's Avatar
My apologies Jeff, I was thinking they were the rusted ones, didn’t read the OP closely enough, long few days. Perhaps my ill-fated ending would be better suited for my Q takeoffs.....
SilVan
dhally
VivaLaVida
Pschitt
