Old 01-19-2016, 03:38 PM   #1
wadewaydo's Avatar
SHURflo On-Demand Diaphragm Pump $40
SHURflo On-Demand Diaphragm Pump Model# 8000-543-236 $40 + Shipping
I bought this pump, and realized it was too oversized for my application.
This SHURflo On-Demand Diaphragm Pump is perfect for boats, RVs and more! Runs quiet and can easily handle heavy-duty jobs, including agricultural spraying and transfer applications. Mounts in any position. Viton valves and Santoprene diaphragm to resist corrosion. Fully repairable pump body. 3/8in. female ports. Self-Priming: Yes, Pressure (PSI): 60, Head (ft.): 6, Mounting Base L x W (in.): 2 1/4 x 3 7/32, Power Supply: 12V, Seal Type: Viton, Amps: 7.3, Max. Inlet Pressure (PSI): 30, Flow (GPM): 1.8, Lift (ft.): 5, Dimensions L x W x H (in.): 8 1/4 x 4, Temperature Capacity (deg F): 170, Inlet Port (in.): 3/8, Outlet Port (in.): 3/8
Buyer pays $15 shipping in the Contiguous US, other locations additional. I accept Paypal only.... Unless you pick it up.
1995 Econoline E-150 Custom Campmobile "Jupiter I" RB, 4wd Dana 60s, 93 Eurovan poptop.
1976 VW Type II Transporter Westfalia Campmobile.
1994 Toyota 4Runner,2001 Ford Escape,1970 Chevy El Camino,2 Cargo Trailers, 5 bikes, 4 Kayaks, 1 Canoe
wadewaydo is offline   Reply With Quote
