Old 05-31-2015, 07:26 AM   #1
BrianW's Avatar
SOLD: Wilson MobilePro Cell Phone Amplifier/Booster NEW
Selling a new, never-used Wilson Electronics "MobilePro" (model 271240) cell phone booster. Bought it for a long trip two years ago and forgot to install it before I left (duh). It's been sitting on a shelf ever since. This kit is powered by USB and has both home and car power adapters. Includes magnet-mount antenna, dash mount, USB cable, and 12v and 110v power adapters.
Price is $95, including shipping in the Lower 48.
[Photos to come shortly, having trouble getting them off my phone.]
Details from the Web:
If you experience dropped calls and poor cell phone signal quality in your car, home, or office, then the Wilson MobilePro Cell Phone Signal Booster Kit is the solution. Increasing your cell phone's power by more than 12 times, the Wilson MobilePro significantly improves the performance of your cellular and data devices by increasing the power output of your cell phone signal where you are experiencing a weak signal. Designed for portability and mobility, the MobilePro includes several power adapters, and is easily moved from your vehicle to your home, hotel, airport, or office, creating an improved cellular signal.
At a Glance:
Increases cell phone signal by more than 12 times, improving reception and data rates.
Designed for portability and mobility; great for use in your office, car, hotel, airport, or home.
Plug & Play Kit--easy installation; everything you need is in the box.
Compatible with all US and Canadian cellular providers, excluding iDEN, Nextel, and MIKE.
Setting up the MobilePro takes just minutes. View larger.
Everything you need for better reception is included in the box.
It's All About Power
The primary cause of dropped calls is low signal output power from the cell phone to the cell tower, which limits the phone's ability to communicate with the tower. A typical cell phone provides merely one-fifth of a watt of output power. To address this problem, the amplifier and the included magnet mount antenna work together to increase the phone's output power by more than 12 times over using just the phone alone.
Enjoy Premium Reception and Fewer Dropped Calls
Living or working in an area with limited cell phone coverage, which is caused by natural and man-made obstructions or by living out of range from a cell phone tower, you know how frustrating weak reception can be. By increasing the power output of your cell phone signal, the Wilson MobilePro helps eliminate most of the signal loss caused by these obstructions. It's important to note that the strongest signal is obtained when the MobilePro is within two feet of your cell phone, laptop, or data card. If you sit at a distance greater than two feet, simply set your phone next to the MobilePro booster and use a Bluetooth headset.
The MobilePro comes with several power options, including a vehicle cigarette lighter adapter, a USB power cable, and a standard five-volt AC/DC adapter. The variety of power options ensures that you'll have a boosted signal whether you're driving in your car, traveling with your laptop, or working at your desk. Included with the booster kit is a convenient carrying case that fits neatly inside a briefcase, handbag, or suitcase.
Once installed, the MobilePro can simultaneously support multiple cell phones and data cards. You'll experience fewer dropped calls, clearer call quality, and improved data rates--even with 3G technologies.
Installing the MobilePro
Installation is quick and easy; everything you need for installation in a building or car is included in the kit.
In a Car
To install, simply attach the magnet mount antenna to the roof of your vehicle. Connect the cable of the magnet mount antenna to the amplifier. Mount the amplifier to the dash or other area using the supplied mounting hardware. Power the amplifier using the cigarette lighter adapter, or by plugging the USB cord into your laptop computer. Now you're ready to enjoy a stronger cell phone signal typically within two feet of the amplifier.
Compatible with Most Cell Phone Models and Providers
The Wilson MobilePro is compatible with all US and Canadian cellular providers, excluding iDEN, Nextel, and MIKE. The kit supports CDMA, TDMA, GSM, and AMPS cell phone technologies, as well as data protocols such as GPRS, 1xRTT, HSDPA, EVDO, and EDGE.
Specifications
Frequency: 824-894 MHz / 1850-1990 MHz
Gain: 40dB / 42dB
Max Output Power: 500 mw
Max RF (downlink): +8dBm
Noise Figure: 3.5dB nominal
Flatness: 4dB
Isolation: > 90dB
Power Requirements: 5V - 8V
Connectors: SMA Female
Dimensions: 2 x 4.75 x 1 inches
Weight: 3 oz
Old 06-01-2015, 07:59 AM   #2
BrianW's Avatar
Re: FS: Wilson MobilePro Cell Phone Amplifier/Booster NEW
Photos...
Old 06-01-2015, 08:02 AM   #3
BrianW's Avatar
Old 06-01-2015, 10:00 AM   #4
oldbonesclimber's Avatar
PM Sent
oldbonesclimber is offline   Reply With Quote
Old 06-17-2015, 10:51 AM   #5
BrianW's Avatar
SOLD!
