Old 07-03-2019, 01:21 PM   #1
ujoint suspension alignment tool
Ujoint suspension alignment tool for sale. $35. See ujoints description below.
310 941 1040
Desc: This is the shackle sleeve cutting jig that we've developed to make every install perfect. It can be used with or without a plasma cutter. Use it as a center punch if you plan to use a hole saw, or simply knock out the center to use it as a plasma guide. The jig breaks down into two pieces to maker it easier to ship. Once the front spring hangers are drilled and in place, the jig uses the front spring hole as a pivot and then slides up to the frame at the rear. It ensures a perfectly square shackle sleeve hole every time. A must have for every conversion!
buddy is offline   Reply With Quote
