Old 12-30-2018, 08:12 PM   #11
Originally Posted by WanderingBob View Post
But I'm not sure what you are referring to with the slide tracks mounted on ceiling, won't that still let in some light? .
Bob
The tape sews to the curtain at the top, with a flap above the tape that drags on the overhead, sealing out the light.
https://www.amazon.com/RV-Designer-A...31568211&psc=1
Old 12-31-2018, 06:44 AM   #12
BrianW's Avatar
all good stuff here, but I’m lazy and am still looking for an OEM SMB curtain to buy :-)
Old 12-31-2018, 09:47 AM   #13
KTMRIDER's Avatar
If you aren’t after the thermal benefits of reducing space SMB also makes one that goes over the dashboard/windshield and both driver and passenger windows. This allows use of the swivel seats and all that front space to hang out. My current van has this setup and i normally add some Reflectix against the windows to help.
On my last van I used a moving blanket and some clamps to make a divider when running the 110 AC at camp. I haven’t needed it yet but plan to do the same if I need to run the Starcool and sleep down below in hot weather. It isn’t perfect but reduces the area to cool or heat and definitely works.
KTMRIDER is offline   Reply With Quote
Old 12-31-2018, 06:47 PM   #14
You might need to start a new thread: Ideas for a privacy curtain. Maybe someone will offer up their old SMB curtain in that thread.
Old 01-29-2019, 10:07 AM   #15
privacy curtains
I just got back from a van gathering in San Diego. I saw a lot of variety in privacy curtains but not all were black out or insulated. I definitely want the dual purpose and am leaning towards 2 panels for easier access between cab and living area. I liked the track method (Ive attached a photo) and am deciding between that and snaps. If anyone has ideas or photos, that would be great. Thanks!
rolorun is offline   Reply With Quote
Old 01-29-2019, 11:17 AM   #16
BrianW's Avatar
SMB uses the track setup I believe. Advantage to that is fast and easy deployment. Negative is the curtain stays attached to the track and needs to have a place to store while attached to the track. Advantage to the snap idea is the curtain can be taken down and folded up to be stored someplace more out of the way.
Old 01-29-2019, 05:07 PM   #17
Thanks for your suggestions. I pick up my van in 2 days and then will know for sure which way to go!
