Old 12-24-2008, 10:22 AM   #11
Originally Posted by Greg In Austin
OK, so two questions....
1. Does it really charge in any 12v outlet ??
2. Would a little dap of glyptol or something similar cover the charging light?
I think the red charging light is within the reflector assembly. I like the idea of being able to locate the light based upon the red light, but as it appears that people find it too bright, I wonder how hard it wold be to perform a red-ectomy?
Old 12-24-2008, 12:37 PM   #12
Led light
Jage
I installed a few extra 12 volt sockets in the dash.. When I put the led light in it blew the fuse.. These 12 volt sockets are all a little bit different(if you look at how they make contact). I haven't run one all down to see if it's really charging. But youre right I hate things glowing in the dark..
Jeff
2006 Sportsmobile PSD-----69 Jeepster----BMW1200GS---450 KTM----450YFZ--- 2007 F150----2005 Nissan
myriadmyriad is offline   Reply With Quote
Old 12-27-2008, 09:54 PM   #13
Yes the red is in the reflector. I don't know how hard it is to take apart, but there is probably a wire you can snip to lose the red permanently- if it's not all circuit board it is probably a simple connection to the base.
Old 12-27-2008, 10:16 PM   #14
cellularSTEVE's Avatar
i just put mine in today and am letting it charge up tonight.
i got thinking, if you leave it in there all the time and the red light is on, it will drain your battery (albeit slowly).
steve
Old 12-27-2008, 10:49 PM   #15
Steve, actually this little light is the result of a secret conspiracy between the big gasoline producers and the power companies. See, if you stick one in your lighter, you'll wake up at 2:00 a.m. worrying about your battery charge UNLESS you run the SMB or the Onan at least once a week (using gas) or plug in (using power). There is an evil genius behind all of this who dreams of a world full of SMBs with little red lights that never go out...
1993 E350 SMB, 15M, 84k miles - a cheap date
2006 Toyota Prius because we like clean air
2002 Honda Odyssey - can haul lots of stuff
1972 Mercedes 350SL with 4.5l V-8, just because
Wag more, Bark less, Play well with others.
Psomaki is offline   Reply With Quote
Old 12-28-2008, 10:24 AM   #16
I've found it is a bit distracting when driving too- I catch the red light out of the corner of my eye and think something is wrong, or something is on that isn't supposed to be.
Old 12-28-2008, 01:11 PM   #17
Oh crap. Out it goes.
