Old 11-06-2019, 06:45 PM   #11
Trial and error. I ran them around 75 psi for a while and the van felt like it was bouncing down the road. Dropped the pressure down to around 6p all around and then settled on 55/60. It rides comfortably and handles well at freeway speeds with those pressures.
"A straight line may be the shortest distance between two points but it is by no means the most interesting". Jon Pertwee as Dr. Who, The Time Warrior.
Old 11-06-2019, 08:23 PM   #12
Otter's Avatar
Thanks. I'll give that a try.
Old 11-09-2019, 12:45 PM   #13
Originally Posted by Otter View Post
Larrie, Im interested in how you decided on those numbers (55/60 pavement). I have the 285/17 KO2s and have been trying to determine what a softer-but-safe pavement ride should be be. Im at about 7500 lbs, almost evenly distributed front and rear (rear = +50).
This is a tire pressure calculator that is based off of information you can find on the tire ( Range, Index,rating) and front and rear axle weights. It also has a margin field, this is generally a good place to start.
2004 E350 EB V10 E/PH 2WD
Old 11-09-2019, 08:42 PM   #14
Otter's Avatar
Thanks Greg. It looks like I’ll need to open this on something other than my IPad. Will give it a look when I get to my Mac.
Old 11-10-2019, 11:06 AM   #15
Vanzila's Avatar
Slow Down and Air Down.
Vanzila is offline   Reply With Quote
Old 11-10-2019, 12:46 PM   #16
This is a tire pressure calculator that is based off of information you can find on the tire-greg
Could you please explain what "margin" refers to? Thanks.......
Old 11-10-2019, 12:49 PM   #17
Greg, Thanks for posting this. It shows I am a little under aired on the rear. Will stop by the scales the next time I fully load it to verify the weights. Lucky there is a state run scale a couple of miles away that is on my way out of town.
Old 11-10-2019, 01:15 PM   #18
Margin is a percentage of the per tire rate based off of axle weight, so if you want 10% margin than it will add 10% of the weight to the tire position, and increase the suggested air pressure. So setting to zero just calculates off of the axle weights. I normally give myself 10% margin, I think the tool had 20 as the last input I tested.
So it is just as safety factor that you can add in, to the equation.
greg
Old 11-10-2019, 02:06 PM   #19
Shaking and rattling were the biggest problem with taking our 4x4 SMB off-road or on washboard roads. At the Overland Expo in Flagstaff I saw a solution at the Agile Off-road booth. They showed me the new “bead grip” wheels by Method which help keep the tires from debeading when aired down.
I bought a set of those wheels and based on advice from Agile I now air my 7500 pound van with BFG KO2s down to 25 to 30 psi on washboards. The lower the pressure, the less my expensive SMB gets shaken apart.
I air back up quickly for the highway using an ARB twin compressor.
OurayMark is offline   Reply With Quote
undecided
JOELMUNOZ3
Turtle
rafeman
