Old 03-24-2013, 03:14 PM   #1
deminimis's Avatar
Help Sourcing Flexible, Adhesive-Backed ABS or Whatever.
I've seen this stuff used on rub areas, but can't remember where. Thin, but not too thin (guessing, but maybe. 030 to. 060 thick). I need approx 12"x24" strips to run along radiused corners (automotive, exterior use). Hard to explain, but I bet one of you what I'm talking about. Driving me nuts because I know I've had something that used something like that, but I'm at a loss. Thanks!
Old 03-24-2013, 03:55 PM   #2
Re: Help Sourcing Flexible, Adhesive-Backed ABS or Whatever.
Is this what you're looking for, adhesive backed butyl tape?
http://www.mcmaster.com/#butyl-rubber-strips/=m0shej
Old 03-24-2013, 03:58 PM   #3
Now that I read it again, I don't think what I listed is what you're looking for.
I think you're looking for the screen protector type material.
http://solutions.3m.com/wps/portal/3M/e ... tion/Film/
Old 03-24-2013, 04:06 PM   #4
deminimis's Avatar
Think I may have found it. 3M aerospace tape: http://www.aircraftspruce.com/catalog/c ... eading.php
Seems like I had something similar on my Sport's roof, where it mated to the penthouse seal when closed.
Old 03-24-2013, 04:08 PM   #5
deminimis's Avatar
At $200 for the 6" stuff, I'd better get a sample first. Ouch!
Old 03-24-2013, 04:52 PM   #6
Were you looking for Helicopter Tape?
http://www.amazon.com/gp/product/B000QC ... 9SV5S37N69
It is a tape that stands up on the leading edge of a helicopter blade.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 03-24-2013, 06:42 PM   #7
Sportsmobile's store sells something for the rub areas of the van where the penhouse hits. It's Avery UHA (or so marked; couldn't find that anywhere online). It's got a rough surface, unlike the ones mentioned. The helicopter tape is pretty tough, I expect. I used a type of aluminum tape, which has lasted quite a while, although now due to come off.
I found I didn't want anything at all rough cuz it started to erode the penthouse rubber. I may just leave it; regular use of the van seems to rub out any rust anyway.
Rob
Old 03-24-2013, 08:53 PM   #8
I have a partial roll of the Avery UHA tape that I bought from SMB West several years ago. I never used it for the PH because I Line-X'ed the roof. But it is only 1.5 " wide. I don't consider it rough surfaced though like the one comment mentioned. This has a smooth finish. If you want a sample to see if it is a suitable material for you PM me your address and I'll send you a sample. I don't know if it is available in wider widths.
Pat
PatO is offline   Reply With Quote
Old 03-24-2013, 10:24 PM   #9
AndrewST's Avatar
Hi PatO,
Your partial roll is it enough for a penthouse top?
If yes and you think of selling it I would be interested.
As I am staying at Deminimis place he would see the sample at the same time...
Andrew
Old 03-24-2013, 11:59 PM   #10
I think it was sold as enough for a penthouse but I've been consuming it on other things. Probably only 3/4 (guess) left so sorry. I could measure it but quite sure it would be short. From SMB the full roll was about $50 as I recollect and I would think would still be available.
Pat
Agnes
ranchero
Rex
Tomboy
