Old 03-24-2013, 02:14 PM   #1
deminimis's Avatar
Help Sourcing Flexible, Adhesive-Backed ABS or Whatever.
I've seen this stuff used on rub areas, but can't remember where. Thin, but not too thin (guessing, but maybe. 030 to. 060 thick). I need approx 12"x24" strips to run along radiused corners (automotive, exterior use). Hard to explain, but I bet one of you what I'm talking about. Driving me nuts because I know I've had something that used something like that, but I'm at a loss. Thanks!
deminimis is offline   Reply With Quote
Old 03-24-2013, 02:55 PM   #2
Re: Help Sourcing Flexible, Adhesive-Backed ABS or Whatever.
Is this what you're looking for, adhesive backed butyl tape?
http://www.mcmaster.com/#butyl-rubber-strips/=m0shej
Old 03-24-2013, 02:58 PM   #3
Now that I read it again, I don't think what I listed is what you're looking for.
I think you're looking for the screen protector type material.
http://solutions.3m.com/wps/portal/3M/e ... tion/Film/
Old 03-24-2013, 03:06 PM   #4
deminimis's Avatar
Think I may have found it. 3M aerospace tape: http://www.aircraftspruce.com/catalog/c ... eading.php
Seems like I had something similar on my Sport's roof, where it mated to the penthouse seal when closed.
Old 03-24-2013, 03:08 PM   #5
deminimis's Avatar
At $200 for the 6" stuff, I'd better get a sample first. Ouch!
Old 03-24-2013, 03:52 PM   #6
Were you looking for Helicopter Tape?
http://www.amazon.com/gp/product/B000QC ... 9SV5S37N69
It is a tape that stands up on the leading edge of a helicopter blade.
Old 03-24-2013, 05:42 PM   #7
Sportsmobile's store sells something for the rub areas of the van where the penhouse hits. It's Avery UHA (or so marked; couldn't find that anywhere online). It's got a rough surface, unlike the ones mentioned. The helicopter tape is pretty tough, I expect. I used a type of aluminum tape, which has lasted quite a while, although now due to come off.
I found I didn't want anything at all rough cuz it started to erode the penthouse rubber. I may just leave it; regular use of the van seems to rub out any rust anyway.
Rob
Old 03-24-2013, 07:53 PM   #8
I have a partial roll of the Avery UHA tape that I bought from SMB West several years ago. I never used it for the PH because I Line-X'ed the roof. But it is only 1.5 " wide. I don't consider it rough surfaced though like the one comment mentioned. This has a smooth finish. If you want a sample to see if it is a suitable material for you PM me your address and I'll send you a sample. I don't know if it is available in wider widths.
Pat
Old 03-24-2013, 09:24 PM   #9
AndrewST's Avatar
Hi PatO,
Your partial roll is it enough for a penthouse top?
If yes and you think of selling it I would be interested.
As I am staying at Deminimis place he would see the sample at the same time...
Andrew
2009 E350 window RB 6.0 PSD Quadvan 4x4 with EB pop top
2003 E350 ambulance 7.3 PSD Quigley
2007 Jeep JK for local offroad
AndrewST is offline   Reply With Quote
Old 03-24-2013, 10:59 PM   #10
I think it was sold as enough for a penthouse but I've been consuming it on other things. Probably only 3/4 (guess) left so sorry. I could measure it but quite sure it would be short. From SMB the full roll was about $50 as I recollect and I would think would still be available.
Pat
Woodstock
woodstock
Otter
