Re: Looking for a good electrical RV shop in Seattle/Bellevue,WA
Sounds similar to a problem I had. Driving the van every week seemed like enough. But, when I went to use the house batteries, they were nearly dead.
Turns out I had a bad connection at the battery separator. A little bit of unseen corrosion.
Here is where you have to be carefull. Both the big wires go to the batteries (one may have a circuit breaker, the one to the starting batteries doesn't seem to). I had to remove the big wires, wire brush them and the terminals, being careful not to touch anything else, grease the clean connections and reassemble. The grease keeps out air and prevents further corrosion.
After that, everything worked as intended. Except for the fact the house batteries had been killed from the lack of charging for too long. Another long story with much anguish followed.
That issue prompted me to finally buy and install a solar panel. If a similar problem should occur, the solar will keep my house batteries charged, and without any problems the solar also keeps the starting batteries charged.
