Old 04-06-2010, 07:00 PM   #11
Re: Wanting to see or get info on GTRV V/T Top
Taut is an overstatement, but yes there is a bungie around near the top and bottom. I was surprised it is just a bungee- metal ends and all.
Don't take anything as criticism if it sounds that way... it's just really different. I'll be curious as to how you feel about winter camping, and if reflectix is in order or the GTRV walls are warmer.
and then
everything changed
Old 04-06-2010, 07:37 PM   #12
I assumed the bungee was just to make sure the PH walls ended up inside the edges of the PH top when lowering it.
Old 04-06-2010, 09:52 PM   #13
AndrewST's Avatar
Brent,
Thank you for the pictures and the detailed description.
Now I understand the GTRV way of doing.
The reduced height of the stowed bunk is what is disturbing me in this design...
Regarding your upgrade to solar panels, you do not need to add an other pair of gas struts, you can replace the exisiting ones with a harder model (able to have more weight).
Andrew
Old 04-06-2010, 11:53 PM   #14
vwteleman's Avatar
Jage,
No, it didn't sound like criticism. It's good to hear your perspective. Regarding winter camping, I've already had numerous nights in the van up at the ski hill. The GTRV walls are not warmer, I'm guessing, just a single layer of canvas. I've had a few nights down to probably -15C (that's about 5F for you 'muricans , not a particular cold winter up here) with no problems. I've been using Thermarest pads to line the walls, and the Espar kicks out a lot of heat. I am planning to make up some Reflectix panels like yours, but I'm thinking of wrapping them in material similar to my curtains. We also want them for the summer to keep out the sun's heat and early morning light.
Andrew,
Yes, the stowed height of the bunk I suspect is lower than in an SMB. It is behind our rear bench so is not a problem for us. Yes, I discussed upgrading the struts with Roy at Coast Outfitter, and he says we can do either (bigger struts or a second set). I'll cross that bridge when the time comes.
Brent
Guster
Salmon
"Campy"
campy
