Originally Posted by mikracer
What springs did you use?
Moog cc860
I will try to post the front end alignment
FRONT LT ---------- FRONT RT
actual------------------------------- actual
0.4 camber specified range 0.0-1.0------ 0.8
1.4 caster specified range 2.0-7.5------ 1.8
0.04 toe specified range -0.10-0.16------ 0.03
FRONT
actual ---------------- specified range
-0.4 Cross Camber -0.5-0.5
-0.3 Cross Caster -1.0-0.0
1.3 Cross SAI
0.07 total toe -0.19-0.31
REAR
-0.08 Thrust Angle -0.50-0.50
As you can see the Caster is off -0.6 on the left and -0.2 on the right from the minimum.
These are the #'s we came up with after doing an alignment. The van runs straight, does not pull any but does like to follow the groves in the road easily. Am going to give a single steering stabilizer a try to see if it helps.
