Originally Posted by BajaSportsmobile
By the way, you only need to buy 2008 on up rotors and calipers and bolt them right on your current setup. You should probably do the hoses also but don't have to.
With 16" aluminum rims?
Any 16" aluminum rim that will fit on a 2008 thru 2014 stock E350 starting with the factory aluminum wheels.
I'm thinking SMB fitted larger brakes than what came stock with the 350 series on their conversions, the F-450 brakes system...no? Is there a big difference between the brakes on my 2006 350 compared to the 2008 and up 350's? If so I would consider that.
Currently I'm running the Brakeman modified rotors and pads but the calipers are the stock size.
