Old 11-11-2015, 09:46 AM   #31
illking's Avatar
Send a message via AIM to illking
Re: Joined SMB nation
the motor disengages from the trans if you lock the rear brake on a downhill....when you get off the brake you are freewheeling.......then you need to rev the engine to re-engage....that's really the only strange thing.
that downhill section in the photo above (much steeper than looks in photo) would have been a nightmare with a rekluse for me, but i guess its something you get used too. Thats good to know that other than downhills you can still use your clutch and gears as usual.
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
illking is offline   Reply With Quote
Old 11-11-2015, 10:19 AM   #32
The downhills are always much steeper than the photos! it's weird......
The loss of engine braking only happens when the rear wheel is locked up, since the clutch disengages to prevent stalling.......you quickly get used to having to rev the motor to re-engage on downhills.....overall way worth it, especially in slow technical sections.
Old 11-11-2015, 10:31 PM   #33
Originally Posted by BajaSportsmobile
By the way, you only need to buy 2008 on up rotors and calipers and bolt them right on your current setup. You should probably do the hoses also but don't have to.
With 16" aluminum rims?
Any 16" aluminum rim that will fit on a 2008 thru 2014 stock E350 starting with the factory aluminum wheels.
I'm thinking SMB fitted larger brakes than what came stock with the 350 series on their conversions, the F-450 brakes system...no? Is there a big difference between the brakes on my 2006 350 compared to the 2008 and up 350's? If so I would consider that.
Currently I'm running the Brakeman modified rotors and pads but the calipers are the stock size.
Old 11-12-2015, 09:47 AM   #34
FWIW......the 2008+ stock rotors are 13.58" dia....and not usable for 4WD applications. The F450 rotors are 14.52" dia and will just fit with 17" wheels. F350 rotors are 13.62" dia.
The 2008+ Calipers are low profile which helps get them in between the wheels and the rotors.
Old 11-12-2015, 07:57 PM   #35
I'm pretty sure that was what they told me and why the new 4x4's looked like they had larger rims. But heck, that was a long time ago. As mentioned, I just can't justify 8 new tires and rims if I upgraded to the 450 brakes.
Old 02-12-2016, 07:56 AM   #36
SMB OCD's Avatar
Sweet rig!
SMB OCD is offline   Reply With Quote
Old 02-12-2016, 02:36 PM   #37
skyrat's Avatar
Originally Posted by DerPo View Post
love these rims! who makes them?
If you want a good selection of tires and wheels, check out this thread in the 4x4 area...
http://www.sportsmobileforum.com/for...ere-14541.html
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
skyrat is offline   Reply With Quote
