My house battery seemed kicked, so I picked up
one of these.
Customer service at Wholesale Batteries Direct was terrible (emailed and left two messages and didn't receive any info back about when it might or might not have been shipped). But, their pricing was great and it did show up at my house in 5 business days!
Saturday morning I started by raising the van on a cracking pallet for some more clearance. Safety third!
I quickly realized the house battery is probably fine.. I immediately found a loose and dirty ground connection. Oh well. I needed to remove the battery box and modify for AMP motorized running boards, and I wanted to wire for my stereo amplifier, solar panels, and a Xantrex Linklite, so I might as well put this new battery in. So out the old one came (mind you my right arm is recovering from surgery for a broken radius, so I can't lift more than 10 lbs with it). Removed the overly large SMB house battery box:
I'm not sure why it's so large, I thought maybe it came with a larger battery, but I can't find any battery that would fit.. Anyway, I cut it up and re-welded to fit a UB4D. I'm not the best welder in the world, but I can make metal stick.
And cleaned it up with a quick coat of rustoleum:
Then began the wiring. Turns out these Linklites take a ton of wires (I think there are 5 that go to positive, negative, and shunt). I drilled more holes through the floor, and got all the wires in place. Then it was time to put the battery back in place.. With one weak hand and a bunch of 2x4s and a floor jack:
Piece of cake! Now I just need to wire up the Xantrex, mount the solar panels and wire them up, and install the stereo. Maybe next week.
Anyway, old battery charged up in minutes, so I think it's fine. I'm going to load test it when I get home from NYC next week and then throw it up here for sale..
