Originally Posted by tsemmens
I have a 2005 traverse with a ski box on the roof as well. Looking at replacing the lift struts. How many lbs is your upgraded struts? would you go light or stronger or is it just right?
I have the same Traverse, my racks are through-bolted into the overhead tent compartment same as the other hardware needed (rear Scissor lifts and Gas Spring mounts).
Does anyone have images of a Ladder for roof access?
Also upgraded Gas Spring for lift to 200lbs (from 150lbs), found them at NMTsystems to match the same hardware, a bitch to install but figured out how to make a compression tool on this board.
With the Traverse Running Boards/Step, I was concerned about ordering and installing the Aluminess Ladder.
