Old 06-04-2013, 11:58 PM   #11
Re: My new wip...
Nice rig... I'm building up a 1987. Its nice not having to deal with the complexity of computers and sensors... mine is an idi diesel.
jedsled is offline   Reply With Quote
Old 06-27-2013, 09:53 PM   #12
Re: My new wip...
Update...
Van is gutted.
Just got it back from Line-X.
Next I'll drop both fuel tanks and install 3 strips of Mac's Versatrack to accommodate my Sprinter van two seater, sofa-bed, and small custom multiposition table.
After the track is installed I'll cut my new wall panels from King Starboard.
Questions:
What is the best insulation to use for wall cavities? Spray foam would be cool, but seems like the kits would be expensive and messy.
taylorvon is offline   Reply With Quote
Old 06-27-2013, 10:06 PM   #13
Gnarvan's Avatar
Re: My new wip...
Line-X Doghouse?
I'M IMPRESSED!! That stuff is hard core.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-27-2013, 10:14 PM   #14
Re: My new wip...
Ya... it was covered in carpet and gew, so I figured Line-x to match would be cool. I have the factory plastic insert with cup holders, glove box, and map book compartment that slides into the top... should make it look a little more complete.
Old 06-27-2013, 11:18 PM   #15
Re: My new wip...
I'll have to remember that. Seems the gray paint(?) that Ford sprayed mine is rubbing off and showing black
Old 06-27-2013, 11:41 PM   #16
vwteleman's Avatar
Re: My new wip...
Originally Posted by taylorvon
Questions:
DON'T USE SPRAY FOAM. It could warp your exterior body panels due to the expansive forces generated. It could also trap moisture, leading to rust issues.
Brent
Old 06-29-2013, 07:36 AM   #17
Re: My new wip...
Originally Posted by VintageSMB
NICE RIG, (I'm a bit biased since I have a 1990 that is very similar)!
Since we have similar vehicles, a word of caution that may save you a bit of trouble with your Penthouse's canvas: On the under-side of your penthouse top, the (2) plastic ribs that divide the (3) sections of wood paneling used for the head liner have been known to shift to the side.
I've had it happen and I've seen a post about someone else having the same problem. In my case, I did not notice the problem until that plastic piece had torn a hole in my canvas. I ended up loosening (not removing) the wood panels, bit by bit coercing the plastic rib back in place by "massaging" the rib while wearing rubber gloves, and then repairing the torn canvas.
Just feel along the outer edges of those wooden panels (aka headliner) to make sue you don't hLave the same problem brewing.
ENJOY!
Ditto on our 2010, some things never change, but should!
2010 E350 RB 6.0 Diesel
SMB 4x4 PH
jima is offline   Reply With Quote
