07-29-2017, 10:24 PM
#41
When I put my rear Reunel bumper on I had to take off the Original door mounted tire carrier that mounts through the door and is drilled into the door hinges. I had no idea what I was going to do to seal the holes or what would look good and I finally came up with a great solution.....
Door mounted AX
The 2 mounts go right were my holes were and its nice and out of the way for not getting it stolen but still quick and easy to access.
I purchased this Ax, its a great size and reasonable, only $27 on sale right now, I payed about $43
And these mounts:
07-29-2017, 11:15 PM
#42
Got around to Installing this rear Hot/Cold shower and made a separate HOW TO thread about it so other people can find it easier.
http://www.sportsmobileforum.com/for...tml#post208526
11-10-2017, 08:06 AM
#43
Does anyone know what size the 4 bolts are that mount the OEM air filter box on a 7.3l? I found a used one finally (after blowing mine up last year) and decided to ditch my custom one I had made since it was making a little bit of a drone noise with my new 4" exhaust. Unfortunately Ford doesn't sell anything for the air cleaner so its been very hard finding parts for it since most get damaged from a crash if they are at a junkyard. Anyway it might be a long shot but if anyone has any idea what size those 4 bolts are I would be super grateful, couldn't find anything in my bolt drawer that would fit to give me an idea.
11-10-2017, 09:16 AM
#44
Door mounted AX
And these mounts:
Man that's a slick set up. May have to barrow that idea
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
11-10-2017, 12:47 PM
#45
Good idea!
11-12-2017, 10:48 AM
#46
Thank you both, now i just need to figure out what to do with the 2 little holes that had the cut up E350 logo.
Still hoping someone knows where I can figure out what bolt size holds the air intake down to the engine bay on a 7.3l. Might just have to buy a bunch and do process if elimination.....
11-12-2017, 01:42 PM
#47
I've found a few of those bolts at the junkyard. F250 and f350 from that era had them as well. Not just the 7.3 engine. I'll look around for some spares
Sent from my SM-J327V using Tapatalk
11-15-2017, 09:16 AM
#48
Yeah I found 3 of those bolts. let me know if you want them.
11-15-2017, 09:18 AM
#49
Awesome, thanks for looking into that, ill send a PM.
04-08-2018, 09:53 AM
#50
Such an awesome build. I have 2 questions. Where did you find the cork underlayment for your floors? How did you prep your bumpers for paint/rhino lining?
