02-07-2013, 03:19 PM
NEW RIMS AND TIRES
just got my new rims and tires
TOYO TIRES LT285/75R16 Open Country AT 2's
AMERICAN RACING ATX SERIES TEFLON COATED 16"rims
2011 E-250 Home Build 2WD
Action Van 4" Lift
American Racing ATX Black Teflon Rims
Toyo AT 2's 285/R75-16's
1959 Chevy Apache Hot Rod
02-07-2013, 03:39 PM
Re: NEW RIMS AND TIRES
Nice!!!
02-07-2013, 04:51 PM
Nice, I wish I went with Toyo's
Callsign KK6GIY
02-07-2013, 05:32 PM
nice man, those look really good!
you should post up specifics for everyone. offset, rim size (diameter and width), tire size, and which toyo tire you went with.
im shopping for tires currently myself. toyo m55's come highly recommended, but they are spendy. might have to settle for a toyo or nitto at tire.
02-07-2013, 06:06 PM
Originally Posted by shenrie
nitto at tire.
viewtopic.php?f=3&t=9615&hilit=nitto
02-07-2013, 07:32 PM
I like the look a lot! You did good.
Mike and Kris
2006 Ford E350 6.0 PSD, RB 50, 4x4
02-07-2013, 07:53 PM
IF those are 16" rims could you verify they are PN 39816882 please. (4.5 back set, 0 offset, 16x8).
Does anyone have a good side picture of a Baja Tan 4x4 van with black rims?
Related question for anyone - what do you torque your lug nuts to for these aluminum rims? I had been going with the steel wheel 140# spec and I have experienced some cracks between the hub and stud holes.
02-07-2013, 11:32 PM
150 lbs.
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
02-08-2013, 08:05 AM
Cool!
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
02-08-2013, 08:40 AM
Hi;
JJ what brand is that aftermarket side window on your rig? I like the flush mount look of it.
Regards,
Gavin
