Originally Posted by grinnelljd
I realized I had some self-adhesive foil covered butyl mat, used for sound dampening car doors, and thought it would be the perfect material to add a little extra insulation to our RV fridge. It may also quiet any rattles in the fridge body.
That should work, but you may have the unintended consequence of causing your fridge to run hotter. The metal fridge body does a pretty decent job of radiating heat, so by insulating that, you may cause your fridge to have to work very hard.
I would let the fridge run for 6-8 hours, and then place your hand on various parts of the fridge body to see how hot it gets.
Could you place the insulation on the interior of the cabinet instead, where it's out of sight?
