Old 05-31-2012, 04:58 PM   #1
cygvan's Avatar
quigley or advanced
can use some advice on adding 4x4 to this:
luxury smb
Red Zeppelin - 2003 Chevy Express 2500 6.0L 2WD RB
cygvan is offline   Reply With Quote
Old 05-31-2012, 06:52 PM   #2
BIGVANS's Avatar
Re: quigley or advanced
Don't you mean this? (The Real FIRST camper van)
http://www.autoblog.com/photos/100th-an ... of-the-rv/
http://www.rvhotlinecanada.com/RV-Histo ... -resources
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 05-31-2012, 07:04 PM   #3
twogone's Avatar
"Tests showed that towing a Curtiss Motor Bungalow, as it was then known, actually increased the carís top speed.Ē
Fiddna start towing me some sh!t when I wanna raise my top speed
'95 SMB E350 Quigley 7.3
http://www.taylorarts.com
Vanna
gahamby
LiamMobile
Shyll
