10-13-2015, 08:40 PM
#61
Re: Sheriffdoug's Sportsmobile Engine Rebuild
2008 Yellow Ford E350 6.0 diesel eb50 4x4, Front E Locker, Asheville Eng Rebuil 20th @ 261miles, ARP Studds, 200amp Alternator, Performance Aluminium Radiator, OnBoardAir, RoadmasterActiveSuspension, Front & Rear Aluminess with Spare Tire Carrier, Aluminess Roof Rack, Titan Aft 30gallon Fuel Tank.
10-14-2015, 03:43 PM
#62
That there is pretty..........
10-15-2015, 08:43 AM
#63
Sure does look nice. Love the repainted engine bay.
I'm curious which aluminum radiator you went with and the fit.
2011 VW TDI Golf for hwy fun
10-15-2015, 09:17 AM
#64
Performance All Aluminium Radiator wwwperformanceradiator.com
Cheers, Doug
10-15-2015, 11:36 AM
#65
Cheers, Doug
Cool, I'll be interested in the fit and how well it works out for you.
Since you are doing an EGR delete are you also replacing the up-pipe? The are known to crack once you remove the support of the EGR cooler. I'm looking at this one but not sure I'll have it ceramic coated which some think helps with heat. http://www.rudysdiesel.com/_e/Turbo_Upg ... ellows.htm
10-15-2015, 11:45 AM
#66
Any reason why them Doug? Although mine is a newer stock version,
I'm looking at replacement later this year if I can justify a reason to
replace one that's only a couple years old. I also have the Starcool
so size might be an issue with the added fans. Any added cooling on
the 6.0 would be worth the change.
10-15-2015, 08:03 PM
#67
10-16-2015, 08:55 AM
#68
10-16-2015, 10:39 PM
#69
Front Bullbar reinstalled.
10-17-2015, 06:17 AM
#70
daveb,
Did not want the factory OEM with plastic tanks, top & bottom of the radiator.
All aluminium, bigger tanks, top & bottom, better heat dispersal.
http://www.performanceradiator.com
These radiators are used in racing engines.
With bonnet vents, Air scoop under front bumper, better radiator, fan programming with JCT Tuner, no hard revving, engine will run cooler.
Racing, not something I am interested in.
Cheers, Doug
