Originally Posted by bettyford
What dont you like about the little Buddy heater? if you dont mind me asking. At this point thats all I have as well.
Great Pictures
Thanks
Ron
A couple things since you asked. I put reflectix over all the windows and in the PH. I also used thermarest pads in the PH. It actually kept the van a good temp with the 4 of us in it and dog. At about 3 am I woke up and it was starting to get pretty cold in the van so I turned on the buddy heater since I hadn't used it until then that evening. It wouldn't lite. I think since the van is so tight and the 4 of us in it maybe the oxygen level was already lower or it was too cold inside?? I opened the side window and after 30 times it finally lit. In the process I woke everyone up. I put it on high for 30 minutes and it warmed the van up nicely. However it gives off an odor and it gives me a suffocating sense as well as my wife. Also having a lit flame on the floor of the van with kids in the PH did not sit well in my mind. I could see one of them coming down to get in our bed because of cold or using the portapotti and knocking it over and catching us on fire. I couldn't sleep with it running. I shut it off and then went through the process of starting it again around 7:30 am and again it wouldn't light. This time it woke everyone up for good. Finally got it lit after 30 times or more.
Since home I have tested it and it lights on the first try everytime. I think it is affected by the cold more so than anything. Also I had previously burned off the odor from new having it on high for a few hours to break it in. The odor we smell is from burned propane and it is not a pleasant odor faint as it is. Looking for something vented to the outside.
Looking at the Webasto 2000 gas version or the espar airtronic D5 gas version. Going to stay away from propane as I have heard it is louder and also I won't have to hassle with dual fuels. Got a quote from Van specialties in Oregon to install the Webasto gas version for $2k.
edit; Our snow camping experience prior we had the same results with the buddy heater of not lighting in the cold but working perfectly at home in a warm environment. Also the buddy heater never set off our CO detectors in the van even with the odor.
