Re: The Yeti (My first Post as a SMB owner)
Over the weekend I did a quick one nighter with the dog. I had planned on camping North of Sedona, but quickly found out the ground was like soup when I turned off the main road. Made it about 200 yards before I got stuck trying to turn around. The recovery went ok as I had my TREDS, tow strap, shovel, D-shackles and winch. I was able using all to get back on the main road. I then backed up the entire way to the main road with some throttle help. This lead to an issue that I needed to correct. All my recovery gear was inside the van under stuff. I was a bear moving things around to get everything out ankle deep in mud. This is my solution:
I mounted the TREDS on the spare tire:
I added the axe, tow strap and shovel to the carrier as well:
Everything is bolted down so it does not walk away. I can't decide if I want to put holes in my tire cover or leave it off. The Yeti is garage keep, so no huge sun issue. I know it may take a little work to get off, but at least everything is in one place and outside.
TexGX
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
