Old 12-13-2014, 08:18 PM   #61
TexGX's Avatar
Re: The Yeti (My first Post as a SMB owner)
I have been playing with the idea of an inside shower. One reason is the wife and another is for times when outside is not possible. This is what I came up with:
The head attaches to a bracket on bed platform. Curtain hangs using items already installed. Need to get one more curtain.
I used a quick connect at the sink. The hose just twists on and off.
It all fits in the base. You can see from this picture that the base has a drain connection that can be opened when I have my grey water hose attached. This can be drained in to a safe area or drain at rv park.
TexGX
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
TexGX is offline   Reply With Quote
Old 12-13-2014, 08:33 PM   #62
DisabledExplorers's Avatar
Well if you aren't going to post pics of the shower in action then what is the point?
Then again I don't have strong enough welding googles to protect my eyes
Looking forward to hearing how it works for ya, anything to get the ladies out with us more often.
Go out and play in the dirt!
DisabledExplorers is offline   Reply With Quote
Old 12-13-2014, 08:41 PM   #63
TexGX's Avatar
I don't need to get kicked off the forum. I plan on doing a test run to see how it works and how much water I use. This way I know before being out and running out of water. I hope it gets the wife out. We will see. If not at least I will smell better.
TexGX
TexGX
Old 12-17-2014, 04:09 PM   #64
TexGX's Avatar
Added a map on the bed platform. I like it a lot!
TexGX
TexGX
Old 12-17-2014, 04:15 PM   #65
Pschitt's Avatar
Great idea !
Old 12-17-2014, 04:45 PM   #66
twogone's Avatar
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 12-17-2014, 05:36 PM   #67
TexGX's Avatar
Thanks. Target had them with the kid wall clinging art. I almost got the Marvel Avenger one, but decided the map worked better.
TexGX
TexGX
Old 12-18-2014, 07:35 AM   #68
What is the base for the shower? It has a drain in it? That looks really handy and I would love to have a shower in my van.
Joanie is offline   Reply With Quote
Old 12-18-2014, 05:26 PM   #69
TexGX's Avatar
Joanie,
It is a pan to mix cement in. I got it at HD for $5+. I cut a whole in it and put a garden hose connector with a valve so I can have it open or closed. I have not given it a final test but seems like it should work.
TexGX
Here is link to tube:
http://www.homedepot.com/p/Plasgad-Medi ... /202086173
TexGX
Old 12-18-2014, 06:48 PM   #70
I've always entertained the idea of using a bilge pump to push the pan water into the sink but the tank is so small that you'd probably have to keep the tank drain open. In a CG that might not be the best idea and I really don't have an idea what soapy water will do to the bilge pump but the ones in my boat don't have an issue with oil. Maybe it would be a helpful solution... I don't know.
