Old 10-09-2008, 10:37 AM   #1
Updating the "Sand Box"
Went to 315's on 17" Mojave's
Next will be lifting the rear 2" or so. Then ladder, changing the swingouts, awning etc. All a part of bringing the 2003 up to 2008.
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
Old 10-09-2008, 12:02 PM   #2
Oni
Looks nice!
Have you tried out the new kayak yet?
Oni is offline   Reply With Quote
Old 10-09-2008, 12:20 PM   #3
Originally Posted by Oni
Looks nice!
No dang it!... been too busy to get away.
Old 10-09-2008, 12:56 PM   #4
Blackeye's Avatar
Re: Updating the "Sand Box"
Very nice! The new wheels really improve / update the look. Nice choice.
"I wonder as I wander out under the sky..."
In between rigs at the moment.
https://www.overlandtraining.com/ Overland Certified #OC0008
Blackeye is offline   Reply With Quote
Old 10-09-2008, 03:33 PM   #5
calclimber's Avatar
Did You have to do any gear changes, speedo changes. The tires look awesome, now I'm jealous.
Quality doesn't come in a twist off
Craig
05 EB 50 V10 4x4 Baja Tan
calclimber is offline   Reply With Quote
Old 10-09-2008, 04:48 PM   #6
Nope, the 4.11's with the v10 actually seem to be just fine. They seam to be just right. Now if i was rockcrawling or doing anything serious i'd be at 4.56 or maybe even 4.88. My speedo was 3mph off and now its 5. It's not that big of a difference.. and actually at highway speed it feels like the truck is working less (flat ground). My crawl ratio went down, but we do fire roads and mild 4 wheeling, so im good. If i went any larger, i'd re-gear.
Old 10-09-2008, 09:29 PM   #7
surfgeek33's Avatar
Looking good Dave!
What PSI are you running?
-Ray
"I do, cellularSTEVE" :o)
Old 10-09-2008, 09:31 PM   #8
Thanks guys
50psi at 3194. However for some reason it doesnt look/feel like enough to me. But thats what specs call for. I used to run 80 in the 285's. What are you guys running? I feel like i need at least 15 psi more.
Old 10-10-2008, 06:11 AM   #9
charlie56's Avatar
I have the BFG 315’s and have been running them at 50 psi. I have 12k on one pair, the other had to be replaced due to an alignment problem, but the original pair at 50psi have a even wear pattern. On a “cold” morning (that’s 40degrees for me) the Hella TPM says they are at 43 psi which does “look” low. I drop them down to 30psi for 4x4 trails and washboards.
... Charlie
KZ6T
Old 10-10-2008, 07:41 AM   #10
surfgeek33's Avatar
I run my 315's at 50 PSI (rear) and 45 PSI (front) That's what SMB recommends for the BFG's, however, I do agree with adventureduo. It seem a little low, but I think 50PSI is the max cold on the 315's.
