Old 05-01-2019, 11:54 AM   #1
BenJJ's Avatar
Oriflamme Canyon and Mason Valley Truck Trail
Did a quick weekend trip out to pinyon mountatin and Oriflamme Canyon in the anza borrego desert. Got a nice campsite with a small creek running next to it.
It was our first trip without Clif and Bemerritt got to test his new land cruiser setup. After getting the pop top set up in less than a minute I got to enjoy a beer while watching him set up his tent...
Ran into a rattlesnake on our hike which was kinda cool.
BenJJ is offline   Reply With Quote
Old 05-01-2019, 12:07 PM   #2
BenJJ's Avatar
We started going up the mason valley truck trail which was a little more difficult than expected. some pretty steep and rocky switchbacks going up the side of the canyon. Unfortunately we got to a tight spot which the van was a little too wide to pass. There is a small chance I could have squeezed by but I was about 6 inches away from a massive boulder on the left side and the right front tire was wedged up against a slick rock wall. Without 4wd I wasn't able to climb high enough on the right side of the trail to get around the boulder. Typically i can use speed and momentum to get make 2wd sufficient in the majority of situations but obviously was not able to in this case. The van was wanting to slide down the wall and into the rock.
I ended up reversing back around 100 yards to a turn around spot. Consequences of trying to squeeze by were to severe. Reversing that far along the side of a mountain was nerve racking to say the least.
Old 05-01-2019, 12:11 PM   #3
Marcel Huijser's Avatar
Looks like a wise decision
Marcel Huijser is offline   Reply With Quote
Old 05-01-2019, 12:12 PM   #4
BenJJ's Avatar
Video of the van on a steep switchback
https://youtu.be/Km3AjvhBHPI
why do I suck at videos? can't figure out how to get it to embed and not link
Old 05-01-2019, 12:16 PM   #5
Awesome thx for sharing!
Zappo is offline   Reply With Quote
Old 05-01-2019, 12:43 PM   #6
BenJJ's Avatar
Based on a recommendation from another forum member I also bought and tried out the coleman oven. Worked like a charm and packed flat so it fit right on top of my stove in the same plastic bin.
I also tried out a shower setup for the first time. Got a camplux tankless propane heater and shurflo 12vdc pump. Brought a 20lb propane tank and battery buddy to run it off. The original plan was to throw the inflow tube to the pump in a water jug and run it off that, but given that we found a little fresh water creek we moved the setup to the creek and just ran it from there. Worked like a charm! Many improvements to be made for sure, but it wasn't bad for a test run.
(No name yet)
Orv
Dusty
capnkurt
