Originally Posted by vlamgat
Not sure what that thread reference was supposed to say with respect to this thread which, is largely about chips and trannies. That reference is about tranny temps. I had seen it on a prior research mission and absolutley categorically reject its conclusions which amongst others are: stick to dino fluid for transmissions; and wrapping exhausts pipes and/or turbos reduces EGT.
From the original poster:
"Found another down side to the new exhaust system. My transmission temps are as high as I've ever seen them on a long hot climb. I'm guessing the new exhaust comes much closer to the transmission and cooling lines so it's heating everything up. In fact the new exhaust is within a 1/4 inch of the transmission now. I'm going to wrap the exhaust from the turbo back and see if that helps."
From daveb....this same thread...
"Tom is it just because of the size of the exhaust tubes itself or did they not bend it out enough to gain clearance? FWIW I wrapped my stock exhaust and it kept my trany temps from going over 220.
Looking forward to your solution.
Dave"
For those that might have the same exhaust system, the same issue, or are just interested in others findings it might be useful info. For you it might not be. That is why I put a link...
Eric
