MG went to work precisely measuring the proper depth of the bumper to the early front end. More of his adapter pieces were added;
Seeing how the 30" Rigid E1 looks;
While I could have fit a 40" E1 on there, it would stretch past the bottom of the grille, so it was decided to stick with the 30".
While ARB states that the Warn 16.5Ti(the winch I was originally thinking about, thanks to advice from Chris at UJOR), is meant to fit into this bumper, in my winch research I decided on what I feel is an even better option, the ComeUp Seal Gen2 IP68 Waterproof Series' 16.5S(bolt pattern is the same 10.0" x 4.5" as the Warn);
SEAL GEN2 16.5s, 12V WinchÂ*| COMEUP USA
ComeUp used to make many of the Superwinch's for Superwinch, and I'm told that ComeUp is the #1 winch line in Australia, and Asia too I believe.
One of my search and rescue teammates works at ComeUp USA and schooled me on some advantages of it vs the Warn 16.5Ti;
ComeUp 16.5S vs Warn 16.5Ti
5.8hp vs 4.6hp
343:1 vs 315:1
1/2"x82' synthetic vs 7/16"x90' wire
132lbs vs 138lbs
Contactors vs solenoids(pretty unique difference when it comes to long term reliability)
The ComeUp 16.5S fitted to the ARB(might be the first time this was done--was the first Chad at ComeUp had heard of one going into an ARB);
Whoops, having some contact issues with the T-handle up against the bumper, and thus the bolt pattern is a bit off;
Good thing this isn't MG's first rodeo! Taking matters into his own hands, the aluminum end cap was removed and re-clocked to put the T-handle at the bottom of the bumper(the only good option). Notice the beefiness of the gears;
There, that's a bit better;
He clearanced the bumper for the new T-handle position (ace fab work here by MG--watching this guy in his element is simply incredible!);
However, since the '92-07 bumper frame horns are sticking further out than the '08-15's do, and in order to allow the best approach angle possible on the '92-07, the bumper needs to suck in towards the van as much as possible, while also keeping in mind the correct aesthetic for the side bumper "wings";
