Old 01-28-2008, 03:57 PM   #11
pjpvi's Avatar
Ken -
I live in the east bay in San Ramon, so I may take you up on the offer.
I don't recall a meeting up at Kirkwood (or ever having my van up there). Must be someone else.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 01-28-2008, 05:53 PM   #12
Greg In Austin's Avatar
What about replacing the existing tank with one of the larger tank options?
I think I remember a 16 gal and 20 gal option..... (we are going with the 20)
This would seem to simplify (eliminate) the plumbing issues.
Greg in Austin
Old 01-28-2008, 06:01 PM   #13
pjpvi's Avatar
I'd be really curious to see how a 16 or 20 gallon fits under the couch. There is steel framework that would prohibit one big tank. I wonder if there 16 and 20 gallon options are really two tanks? Anyone with a "50" layout and a 16 or 20 gallon configuration want to share what the install looks like?
Phil
Phil
Old 01-28-2008, 06:05 PM   #14
Our 20 is to be one tank.....
...so I suspect the 16 is also one tank....
Greg in Austin
Old 01-28-2008, 06:14 PM   #15
Anyone got a) pics of one installed and b) HxLxW measurements?
2006 RB50 6.0 Diesel
SMB 4WD
Amsoil
Old 01-28-2008, 06:36 PM   #16
I would take a picture of our 16 gallon tank in the SMB, but it's 10 below zero F and dropping this evening out there in the driveway. It will have to wait until springtime!
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Old 01-28-2008, 06:40 PM   #17
From looking a pipvi's original photo of the 10 gallon tank under the benchseat in an "50" floorplan, our larger tank extends about 6 to 8 inches further to the right under the seat. The open space to the right (driver's side) of the tank is just big enough for a camera tripod or two, but not much else.
Old 01-28-2008, 07:22 PM   #18
So you're saying the metal support thing is also more to the right; that the actual seat construction is different?
SMB 4WD
Amsoil
Old 01-28-2008, 07:47 PM   #19
Dang it kzemach, now you made me do it! I had to go out in the blizzard and take a look at our SMB's fresh water tank.
The 16 gallon tank is 16" wide from left to right, and the open space to the driver's side is 14" wide. I could not see the horizontal black support (running from front to rear) visible in pipvi's bench seat photo at the start of this thread. But it was dark and cold as hell at 12.8 degrees below zero! There might be a support further to the back of the seat, but I couldn't see it with the light from my headlamp.
We have the regular EB-50 bench seat floor layout, with a propane furnace taking up much of the left rear passenger's side under the seat and bed.
I will see if I can take a pic in the next several days when the temp is supposed to get back up to the plus 20s.
Old 01-28-2008, 08:48 PM   #20
pjpvi's Avatar
Well Ed, now you made me go out in 45 degree weather to take some rough measurements. I would guess that your tank fits between the couch supports and your heater ducts are routed differently than mine. There's 17-18ish inches between the supports (didn't look too closely). With vent and some electrical re-work, I could put a much bigger tank between the supports.
Hmmmm .... so many options.
Stay warm!
Thanks -
Phil
Phil
